hi,
I’m trying to make use an AWS IAM role on my telegraf server to access Cloudwatch input metrics.
Using AWS Linux 2016-09, installed via yum.
If I create a role with minimal permissions, like just accessing Cloudwatch, telegraf fails:
iam role permissions:
“Version”: “2012-10-17”,
“Statement”: [
“Action”: [
“cloudwatch:Get*”,
“cloudwatch:List*”
“Effect”: “Allow”,
“Resource”: “*”
telegraf logs:
2017-04-07T21:39:37Z I! Starting Telegraf (version 1.2.1)
2017-04-07T21:39:37Z I! Loaded outputs: influxdb
2017-04-07T21:39:37Z I! Loaded inputs: inputs.processes inputs.swap inputs.system inputs.disk inputs.kernel inputs.mem inputs.cloud
watch inputs.cpu inputs.diskio
2017-04-07T21:39:37Z I! Tags enabled: host=ip-10-30-17-125
2017-04-07T21:39:37Z I! Agent Config: Interval:10s, Quiet:false, Hostname:“ip-10-30-17-125”, Flush Interval:10s
2017-04-07T21:39:40Z E! ERROR in input [inputs.cloudwatch]: AccessDenied: User: arn:aws:sts::awsaccount:assumed-role/influxdb/i-instance is not authorized to perform: sts:AssumeRole on resource: arn:aws:iam::awsaccount:role/influxdb
status code: 403, request id: b4931cdd-1bda-11e7-9dcd-c3f867c70393
if I give the IAM role full admin access, it works.
It appears I’m supposed to give the role sts:AssumeRole capabilities.
Any working example IAM roles would be appreciated.
Thanks!
