Hello guys,
I am trying to create task that will run every 3 hours and it will calculate pearsonr correlation so far I got:
option task = {
every: 3h,
corr1 = from(bucket: "aggregates")
|> range(start: -3h)
|> filter(fn: (r) => r["_measurement"] == "sensors")
|> filter(fn: (r) => r["device_id"] == "1")
|> filter(fn: (r) => r["device_name"] == "device_1")
|> filter(fn: (r) => r["location"] == "ke")
|> filter(fn: (r) => r["_field"] == "temperature")
corr2 = from(bucket: "aggregates")
|> range(start: -3h)
|> filter(fn: (r) => r["_field"] == "pressure")
data = pearsonr(x: corr1, y: corr2, on: ["_time"])
data
This script will calculate and save result into data variable now I want to write this data return value into bucket called test.
I have edited the above script to:
option task = {
every: 3h,
|> range(start: -3h)
|> range(start: -3h)
data
|> to(
bucket: "test",
org: "**",
token: "***",
measurementColumn: "correlation",
tagColumns: ["temp_press"],
host: "***",
This will result as an errror.
Downloaded data as csv is in this format and I do not understand why is there x, y for every entry:
,result,table,_field_x,_field_y,_measurement_x,_measurement_y,_start_x,_start_y,_stop_x,_stop_y,device_id_x,device_id_y,device_name_x,device_name_y,location_x,location_y,_value
I think it might be the root cause why it’s not working and I cannot see calculated data in new bucket called test.
