Thanks for your reply. It means alot to me. I am trying to fix this issue for last 7 days. I am new to influxdb so i am unable to debug the error.
I have used the same approch you suggested. But i always get some error that i am unable to debug
[[inputs.mqtt_consumer]]
servers = ["abc:8883"]
username = "abc"
password = "xyz"
topics = ["abc/+/mission/waypoints"]
data_format = "json"
name_override = "mqtt_json1"
[[processors.execd]]
command = ["C:\Users\abc\AppData\Local\Programs\Python\Python312\python.exe", "D:\Docker-influxdb-mqtt\transform_waypoints.py"]
and here is my transform_waypoints.py that i am using to transform my input data
import json
import sys
def transform_waypoints(data):
processed_data = []
for i, waypoint in enumerate(data, start=1):
processed_data.append({f"wp{i}": waypoint})
return processed_data
def main():
for line in sys.stdin:
try:
data = json.loads(line)
if isinstance(data, list):
processed_data = transform_waypoints(data)
print(json.dumps(processed_data))
else:
# Pass through non-list data as is
print(line, end='')
except json.JSONDecodeError as e:
sys.stderr.write(f"Error decoding JSON: {e}\n")
if __name__ == "__main__":
main()
I have added the path in docker compose file too
telegraf:
image: telegraf:latest
container_name: telegraf
restart: always
volumes:
- ./telegraf.conf:/etc/telegraf/telegraf.conf:ro
- ./transform_waypoints.py:/etc/telegraf/transform_waypoints.py:ro
But i always get this error when i run the docker container
Error 1:
telegraf exited with code 0
telegraf | 2024-01-30T01:10:01Z I! Loading config: /etc/telegraf/telegraf.conf
telegraf | 2024-01-30T01:10:01Z E! error loading config file /etc/telegraf/telegraf.conf: error parsing data: line 52: invalid TOML syntax
telegraf exited with code 1
Current Error 2:
telegraf | 2024-01-30T02:40:56Z I! [processors.execd] Starting process: C:/Users/akhan/AppData/Local/Programs/Python/Python312/python.exe [D:/Docker-influxdb-mqtt/transform_waypoints.py]
telegraf | 2024-01-30T02:40:56Z E! [telegraf] Error running agent: starting processor processors.execd: failed to start process [C:/Users/akhan/AppData/Local/Programs/Python/Python312/python.exe D:/Docker-influxdb-mqtt/transform_waypoints.py]: error starting process: fork/exec C:/Users/akhan/AppData/Local/Programs/Python/Python312/python.exe: no such file or directory
FYI this is my line 52 in which i am having error
command = ["C:/Users/akhan/AppData/Local/Programs/Python/Python312/python.exe", "D:/Docker-influxdb-mqtt/transform_waypoints.py"]
