just switched to InfluxDB 2.0 and fairly new to Flux and still trying to figure out some things…maybe you can point me to a solution for this requirement:
I’m storing currency conversion rates in one measurement and currency-based values in another measurement, lets say something like this:
time, value, from, to
10:00, 1.03, GBP, EUR
10:15, 1.02, GBP, EUR
time, amount, currency
10:00, 23.55, GBP
10:01, 54.01, GBP
Now I’m looking for a transformation/query that would allow me to convert the “amount” in GBP to EUR based on the conversion rate given at a specific time.
I know I can do a map function to apply a operation to every _value in a table, but in my case I’d need a “dynamic” operation, e.g. multiply _value with conversionrate at the time of the _value’s timestamp.
|> map(fn: (r) => ({
r with
_value: _value * $conversionrate (from the other table at this row's _time)
Is there some way to use a function within the map function to get the conversion rate from the other measurement?
@Reinhard_Weber You can query the exchange rate as part of the map() call. In the example below, I create a custom function that retrieves the conversion rate for a particular currency based on time and returns it as a scalar value. It then uses that custom function inside of the map call:
Thanks @scott!
That looks very promising and I was guessing that this would work somehow like this, just couldn’t figure it out! The “experimental.subDuration” looks interesting.
Exactly what I was looking for!
Thank you @scott you saved me lots of effort figuring this out by myself!
Only thing it noticed is that the subDuration should not contain a negative “d:” this would lead to adding the one hour, should be “1h” to substract from “time”
