Documentation (without using helper function)
|> histogram(bins: [0.0, 10.0, 20.0, 30.0])
What;s the correct syntax to include bin for everything > than last value?
This doesn’t appear to be currently possible. I’ve created an issue for this here: Allow inf bin for the histogram function · Issue #3061 · influxdata/flux · GitHub
Until that issue is worked on, you can work around it by specifying a high final bin or, if you want to be more careful, you can do this:
import "math"
max_value = 1000.0
|> map(fn: (r) => ({r with _value: math.min(x: r._value, y: max_value)}))
|> histogram(bins: [0.0, 10.0, 20.0, 30.0, max_value])
That will prevent the number from being above the highest bin.
I took a further look and there’s also the linearBins function which might help. You can use that function to generate the bins like this: linearBins(start: 0.0, width: 10.0, count: 4) which would generate your specific buckets.
my desired bins are not even close to linear…they are very specific to my use-case, but i thought having last bucket more elegantly +inf was better than having to rip through the series to grab the max_value
Thanks for responding. We now have the issue above for allowing someone to specify +Inf instead of relying on the linearBins function. For now, the workaround is probably the easiest way to get this working now, but I understand that usability is important and the convenience of specifying inf is definitely something we want to have in there.
