Hi everyone,
I’m new with InfluxDB and I have faced this problem: I need to store data coming from multiple sensors, each sensor name is like garage.light garage.door or kitchen.thermostat.temperature. Currently I’m using postgreSQL to store data from sensors and each sensor has a dedicated table with the name of the sensor.
What is the best choice for InfluxDB?
Should I use:
- a single measurement called
sensorswithnameas tag andtimevalueas fields
or - multiple measurements with sensors names as name with no tags and
timevaluefields
What are the pro and cons of each choice? Thanks.
