I need to create different databases with different tick scripts based on parsed input. Is it possible, then, to have one Kapacitor instance process multiple tick scripts?
Thanks.
Thanks.
yes,
first kapacitor can config multi influxdb source
second kapacitor can define multi tick scripts and run these.
you can get it from kapacitor documents
