mbooth
April 27, 2020, 5:42pm
1
HI,
I’m trying to use telegraf with the HTTP plugin,
I want to make two different HTTP inputs, one to a URL with GET - this works
the other with POST and 2 values in the header, plus body
I can’t find a clear method to achieve this.
i understand I will need 2 different [[inputs.http]]
should the multiple headers be [inputs.http.headers] or headers = “xyz”
Cheers
Hello @mbooth ,
Welcome! Please included multiple headers in the http input plugin :
## Optional HTTP headers
# headers = {"X-Special-Header" = "Special-Value"}
And for the http output plugin please use
## Additional HTTP headers
# [outputs.http.headers]
# # Should be set manually to "application/json" for json data_format
# Content-Type = "text/plain; charset=utf-8"
Does this help?
mbooth
April 27, 2020, 11:43pm
3
HI @Anaisdg
your example doesn’t show multiple headers, it only shows a single header
so my telegraf.conf should look similar to the below?
[[inputs.http]]
urls = [
" https://api.weather.com/v2/pws/observations/current?Id=123 ...etc
data_format = "json"
[[inputs.http]]
urls = [
" https://data-api.samknows.one/metric_data "
method = "POST"
content_encoding = "gzip"
body = '{"splits":["MAC_ADDRESS"],"metric":"httpgetmt","chartType":"aggregate"….etc
headers = {"Authorization" = "APIKEY"}
headers = {"Accept" = "application/json"}
Hello @mbooth ,
I believe so. Have you tried it?
liamng
October 21, 2024, 10:20pm
5
single-line , comma-separated works for me. For example,
headers = {"X-Special-Header1" = "Special-Value1", "X-Special-Header2" = "Special-Value2", "X-Special-Header3" = "Special-Value3"}
