MQTT topic parsing: Pivoting doesn't work
I follow the example https://www.influxdata.com/blog/pivot-mqtt-plugin/ to rotate values from a vertical format into a horizontal format.
[[inputs.mqtt_consumer]]
  servers = ["tcp://mqtt.XXX:1883"]
  ## Username and password to connect MQTT serve
  username = "telegraf"
  password = "@{docker_secretstore:telegraf_mqtt_password}"
  data_format = "json"
  topics = [
    "warp/evse/state",
   topic = "warp/+/+"
   measurement = "measurement/_/_"
   tags = "_/_/field"
[[processors.pivot]]
  tag_key = "field"
  value_key = "value"
The topic parsing works, but not the pivoting. Any idea why it doesn’t work?
Hello @alexander-zimmermann,
to pivot the data after ingest you’ll need to use flux for that:
Try adding this to the end of your query before a |>yield() statement
I hope that helps!
Hey @Anaisdg,
thanks for your reply. To be honest, I’m not a DB expert and cannot judge what strategy is the best one. If I understand you correctly, you suggest to not pivot the data before ingesting, but afterward w/ flux, correct?
