I am using mqtt.to() to send data from my bucket to a broker, however the query doesn’t seem to work well,
as you can see below :
I get way more data from my broker than what I get from the database publish message, I have usually around 3 or 6 data per second while I have something like 50 data registered in the database per second.
Here is the command used for the task, i can’t seem to get the _time value in the msg payload as well,
if someone knows how to extract the time ?
import "experimental/mqtt"
option task = {
every: 1s,
from(bucket: "test")
|> range(start: -task.every)
|> filter(fn: (r) => r["_measurement"] == "accel")
|> filter(fn: (r) => r["_field"] == "Newtons")
|> filter(fn: (r) => r["host"] == "ESP32")
|> filter(fn: (r) => r["topic"] == "test")
|> aggregateWindow(every: 1ms, fn: mean, createEmpty: false)
|> yield(name: "mean")
|> mqtt.to(
broker: "tcp://host.docker.internal:1883",
topic: "DB",
clientid: "flux",
timeColumn: "_time",
qos: 0,
valueColumns: ["_value"],
tagColumns: ["test"],
The (~50/per second) tables do appear in the normal querying system when I run the same query, so why doesn’t it work well in tasks ?
Thanks to anyone who can help
