Dear All …
Can I have more than one instance of [[inputs.file]] in csv input format?
I have three different types of csv files to plot…
thanks in advance …
Dear All …
thanks in advance …
@rumekintun,
Absolutely you can! However, it’s worth noting that if you plan to write to multiple instances/different datastores it’s a lot easier to just run multiple telegrafs each configured with an input and output instead of using filtering. <–but filtering is worth knowing about ![]()
