Morning all, i’m not sure if this is in the correct place, but I’m using influxdb attached to home assistant via dockers, I have historical data that can be graffed with grafana using the command:
SELECT distinct("power") FROM "device_tracker.thundercat" WHERE ("domain" = 'device_tracker' AND "entity_id" = 'thundercat') AND $timeFilter GROUP BY time($__interval) fill(linear)
however after rebuilding HA the tracker battery info is now appearing when i use this query:
SELECT distinct("power") FROM "state" WHERE ("domain" = 'device_tracker' AND "entity_id" = 'thundercat') AND $timeFilter GROUP BY time($__interval) fill(linear)
Is it possible to move the historical data to be queried with the new entry? Thanks in advance, and sorry if this is in the wrong place.
