Hi Josh,
I am using InfluxDB v1.8.10 together with Telegraf v1.29.4
In my telegraf.conf you find [[inputs.modbus]] and [[inputs.mqtt_consumer]]
I use DBeaver Lite or sql console to view the InfluxDB contents.
Some select lines: select * from freezer:
1706978555000000000 16 0.071 0.07 1 1 16 0.421 7.739 220 0.35 tele/freezer/SENSOR
1706978495000000000 60 0.27 0.73 1 43 41 0.42 7.738 221 0.35 tele/freezer/SENSOR
This forum tells me, because I am a new user I can’t upload files here. So I will paste conf and log-abstract here.
telegraf.conf:
# Global tags can be specified here in key="value" format.
[global_tags]
[agent]
interval = "60s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = "1s"
debug = false
quiet = false
hostname = ""
omit_hostname = true
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
urls = ["http://192.168.5.69:38086"]
database = "telegraf"
timeout = "5s"
## HTTP Basic Auth
username = "telegraf"
password = "telegraf"
[[outputs.file]]
files = ["stdout", "/tmp/metrics.out"]
data_format = "influx"
[[inputs.modbus]]
name = "SMA"
slave_id = 3
timeout = "5s"
controller = "tcp://192.168.5.79:502"
input_registers = [
{ measurement = "wr", name = "DC_amp_s", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30769,30770]},
{ measurement = "wr", name = "DC_volt_s", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30771,30772]},
{ measurement = "wr", name = "DC_watt_s", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30773,30774]},
{ measurement = "wr", name = "DC_amp_n", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30957,30958]},
{ measurement = "wr", name = "DC_volt_n", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30959,30960]},
{ measurement = "wr", name = "DC_watt_n", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30961,30962]},
{ measurement = "wr", name = "AC_watt", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [30775,30776]},
servers = ["tcp://192.168.5.69:32777"]
## Topics that will be subscribed to.
topics = [
"tele/freezer/SENSOR",
"wem/wem/meter/values",
data_format = "json"
# json_time_format = "2006-01-02T15:04:05"
# json_timezone = "Europe/Berlin"
# json_time_key = "Time"
topic = "tele/freezer/SENSOR"
measurement = "/freezer/_"
## Warpcharger Energy Manager
topic = "wem/wem/meter/values"
measurement = "/wem/_/_"
_telegraf_logs.txt:
2024-02-06T08:12:12.107215872Z 2024-02-06T08:12:12Z I! Starting Telegraf 1.29.4 brought to you by InfluxData the makers of InfluxDB
2024-02-06T08:12:12.107372018Z 2024-02-06T08:12:12Z I! Available plugins: 241 inputs, 9 aggregators, 30 processors, 24 parsers, 60 outputs, 6 secret-stores
2024-02-06T08:12:12.107426284Z 2024-02-06T08:12:12Z I! Loaded inputs: modbus mqtt_consumer
2024-02-06T08:12:12.107466957Z 2024-02-06T08:12:12Z I! Loaded aggregators:
2024-02-06T08:12:12.107498672Z 2024-02-06T08:12:12Z I! Loaded processors:
2024-02-06T08:12:12.107531603Z 2024-02-06T08:12:12Z I! Loaded secretstores:
2024-02-06T08:12:12.107566736Z 2024-02-06T08:12:12Z I! Loaded outputs: file influxdb
2024-02-06T08:12:12.107713119Z 2024-02-06T08:12:12Z I! Tags enabled:
2024-02-06T08:12:12.107747234Z 2024-02-06T08:12:12Z I! [agent] Config: Interval:1m0s, Quiet:false, Hostname:"", Flush Interval:10s
2024-02-06T08:12:12.107793553Z 2024-02-06T08:12:12Z I! [inputs.modbus] Got 0 request(s) touching 0 holding registers for 0 fields (slave 3)
2024-02-06T08:12:12.107835451Z 2024-02-06T08:12:12Z I! [inputs.modbus] Got 2 request(s) touching 14 inputs registers for 7 fields (slave 3)
2024-02-06T08:12:12.107885723Z 2024-02-06T08:12:12Z I! [inputs.modbus] Got 0 request(s) touching 0 discrete registers for 0 fields (slave 3)
2024-02-06T08:12:12.107920314Z 2024-02-06T08:12:12Z I! [inputs.modbus] Got 0 request(s) touching 0 coil registers for 0 fields (slave 3)
2024-02-06T08:12:12.118016158Z 2024-02-06T08:12:12Z I! [inputs.mqtt_consumer] Connected [tcp://192.168.5.69:32777]
2024-02-06T08:12:22.119475088Z wem,topic=wem/wem/meter/values energy_abs=972.7249756,power=439.3598633,energy_rel=972.7249756 1707207132158529530
2024-02-06T08:12:22.119961568Z wem,topic=wem/wem/meter/values power=435.4440918,energy_rel=972.7249756,energy_abs=972.7249756 1707207133125282401
2024-02-06T08:12:22.120007759Z wem,topic=wem/wem/meter/values energy_abs=972.7249756,power=435.8630371,energy_rel=972.7249756 1707207134161150298
2024-02-06T08:12:22.120044705Z wem,topic=wem/wem/meter/values energy_rel=972.7249756,energy_abs=972.7249756,power=441.628479 1707207135197606639
2024-02-06T08:12:22.120079226Z wem,topic=wem/wem/meter/values power=441.5465088,energy_rel=972.7249756,energy_abs=972.7249756 1707207136233215132
2024-02-06T08:12:22.120113039Z wem,topic=wem/wem/meter/values energy_abs=972.7249756,power=442.8178406,energy_rel=972.7249756 1707207137269284519
2024-02-06T08:12:22.120146795Z wem,topic=wem/wem/meter/values power=444.0002136,energy_rel=972.7249756,energy_abs=972.7249756 1707207138305068117
2024-02-06T08:12:22.120205575Z wem,topic=wem/wem/meter/values power=433.7202759,energy_rel=972.7249756,energy_abs=972.7260132 1707207139342095388
2024-02-06T08:12:22.120240540Z wem,topic=wem/wem/meter/values power=435.6862793,energy_rel=972.7260132,energy_abs=972.7260132 1707207140377115607
2024-02-06T08:12:22.120274281Z wem,topic=wem/wem/meter/values power=437.8800659,energy_rel=972.7260132,energy_abs=972.7260132 1707207141412703143
2024-02-06T08:12:32.119637532Z wem,topic=wem/wem/meter/values energy_abs=972.7260132,power=434.7301941,energy_rel=972.7260132 1707207142448288681
2024-02-06T08:12:32.120081262Z wem,topic=wem/wem/meter/values power=437.8299866,energy_rel=972.7260132,energy_abs=972.7260132 1707207143484411261
2024-02-06T08:12:32.120130680Z wem,topic=wem/wem/meter/values energy_rel=972.7260132,energy_abs=972.7260132,power=434.7163696 1707207144542695010
2024-02-06T08:12:32.120170322Z wem,topic=wem/wem/meter/values power=436.7639771,energy_rel=972.7260132,energy_abs=972.7260132 1707207145556790027
2024-02-06T08:12:32.120218276Z wem,topic=wem/wem/meter/values power=438.1010437,energy_rel=972.7260132,energy_abs=972.7260132 1707207146592449081
2024-02-06T08:12:32.120269419Z wem,topic=wem/wem/meter/values energy_abs=972.7260132,power=434.5445862,energy_rel=972.7260132 1707207147627910363
2024-02-06T08:12:32.120316358Z wem,topic=wem/wem/meter/values power=435.7927246,energy_rel=972.7269897,energy_abs=972.7269897 1707207148663445407
2024-02-06T08:12:32.120351479Z wem,topic=wem/wem/meter/values power=434.5674744,energy_rel=972.7269897,energy_abs=972.7269897 1707207149699114154
2024-02-06T08:12:32.120387283Z wem,topic=wem/wem/meter/values power=431.4658508,energy_rel=972.7269897,energy_abs=972.7269897 1707207150735118242
2024-02-06T08:12:32.120487728Z wem,topic=wem/wem/meter/values power=433.756012,energy_rel=972.7269897,energy_abs=972.7269897 1707207151770355197
2024-02-06T08:12:42.119918370Z wem,topic=wem/wem/meter/values power=431.4208069,energy_rel=972.7269897,energy_abs=972.7269897 1707207152806331436
2024-02-06T08:12:42.120387894Z wem,topic=wem/wem/meter/values energy_rel=972.7269897,energy_abs=972.7269897,power=438.5079651 1707207153842350297
2024-02-06T08:12:42.120433953Z wem,topic=wem/wem/meter/values energy_abs=972.7269897,power=436.2527466,energy_rel=972.7269897 1707207154878333787
2024-02-06T08:12:42.120471667Z wem,topic=wem/wem/meter/values power=437.4781494,energy_rel=972.7280273,energy_abs=972.7280273 1707207155949828155
2024-02-06T08:12:42.120524703Z wem,topic=wem/wem/meter/values power=440.4950256,energy_rel=972.7280273,energy_abs=972.7280273 1707207156976356340
2024-02-06T08:12:42.120562231Z wem,topic=wem/wem/meter/values power=436.7272339,energy_rel=972.7280273,energy_abs=972.7280273 1707207158008770176
2024-02-06T08:12:42.120595267Z wem,topic=wem/wem/meter/values power=433.1254272,energy_rel=972.7280273,energy_abs=972.7280273 1707207159022688046
2024-02-06T08:12:42.120628595Z wem,topic=wem/wem/meter/values power=436.4650269,energy_rel=972.7280273,energy_abs=972.7280273 1707207160057473351
2024-02-06T08:12:42.120665340Z wem,topic=wem/wem/meter/values power=438.0372925,energy_rel=972.7280273,energy_abs=972.7280273 1707207161094764478
2024-02-06T08:12:52.120848709Z wem,topic=wem/wem/meter/values energy_rel=972.7280273,energy_abs=972.7280273,power=439.7202148 1707207162130486130
2024-02-06T08:12:52.121412414Z freezer,topic=tele/freezer/SENSOR ENERGY_ReactivePower=46,ENERGY_Voltage=221,ENERGY_Factor=0.69,ENERGY_Power=44,ENERGY_Current=0.288,ENERGY_Total=9.234,ENERGY_Period=1,ENERGY_Yesterday=0.561,ENERGY_Today=0.214,ENERGY_ApparentPower=64 1707207162890414181
2024-02-06T08:12:52.121489988Z wem,topic=wem/wem/meter/values power=435.914917,energy_rel=972.7280273,energy_abs=972.7280273 1707207163190601335
2024-02-06T08:12:52.121528209Z wem,topic=wem/wem/meter/values energy_rel=972.7280273,energy_abs=972.7280273,power=437.9286499 1707207164204142435
2024-02-06T08:12:52.121565876Z wem,topic=wem/wem/meter/values power=437.196106,energy_rel=972.7290039,energy_abs=972.7290039 1707207165239227183
2024-02-06T08:12:52.121600493Z wem,topic=wem/wem/meter/values power=435.9000854,energy_rel=972.7290039,energy_abs=972.7290039 1707207166274876424
2024-02-06T08:12:52.121633500Z wem,topic=wem/wem/meter/values power=436.4159546,energy_rel=972.7290039,energy_abs=972.7290039 1707207167310326131
2024-02-06T08:12:52.121667703Z wem,topic=wem/wem/meter/values power=438.614624,energy_rel=972.7290039,energy_abs=972.7290039 1707207168345453995
2024-02-06T08:12:52.121700387Z wem,topic=wem/wem/meter/values energy_rel=972.7290039,energy_abs=972.7290039,power=436.4590454 1707207169404452344
2024-02-06T08:12:52.121732315Z wem,topic=wem/wem/meter/values power=431.6578369,energy_rel=972.7290039,energy_abs=972.7290039 1707207170418888116
2024-02-06T08:12:52.121767752Z wem,topic=wem/wem/meter/values energy_abs=972.7290039,power=435.12677,energy_rel=972.7290039 1707207171454319467
2024-02-06T08:13:02.121622656Z wem,topic=wem/wem/meter/values power=435.400177,energy_rel=972.7290039,energy_abs=972.7290039 1707207172490710248
2024-02-06T08:13:02.122063624Z wem,topic=wem/wem/meter/values power=434.2456665,energy_rel=972.7299805,energy_abs=972.7299805 1707207173526765252
2024-02-06T08:13:02.122109375Z wem,topic=wem/wem/meter/values power=434.9208069,energy_rel=972.7299805,energy_abs=972.7299805 1707207174562504191
2024-02-06T08:13:02.122233312Z wem,topic=wem/wem/meter/values power=432.5646057,energy_rel=972.7299805,energy_abs=972.7299805 1707207175598789698
2024-02-06T08:13:02.122271984Z wem,topic=wem/wem/meter/values energy_rel=972.7299805,energy_abs=972.7299805,power=433.2807922 1707207176634504868
2024-02-06T08:13:02.122311597Z wem,topic=wem/wem/meter/values power=434.4064026,energy_rel=972.7299805,energy_abs=972.7299805 1707207177672289444
2024-02-06T08:13:02.122362564Z wem,topic=wem/wem/meter/values power=433.1546021,energy_rel=972.7299805,energy_abs=972.7299805 1707207178708185079
2024-02-06T08:13:02.122397688Z wem,topic=wem/wem/meter/values power=430.2150574,energy_rel=972.7299805,energy_abs=972.7299805 1707207179745257249
2024-02-06T08:13:02.122430284Z wr,name=SMA,slave_id=3,type=input_register DC_amp_s=108,DC_volt_s=53007,DC_watt_s=57,AC_watt=66,DC_amp_n=78,DC_volt_n=48452,DC_watt_n=38 1707207180000000000
2024-02-06T08:13:02.122480667Z wem,topic=wem/wem/meter/values power=432.5559082,energy_rel=972.7310181,energy_abs=972.7310181 1707207180780603108
2024-02-06T08:13:02.122513813Z wem,topic=wem/wem/meter/values power=430.8291321,energy_rel=972.7310181,energy_abs=972.7310181 1707207181819292651
2024-02-06T08:13:12.122504384Z wem,topic=wem/wem/meter/values energy_abs=972.7310181,power=428.4508667,energy_rel=972.7310181 1707207182855511753
2024-02-06T08:13:12.123002582Z wem,topic=wem/wem/meter/values power=430.9134216,energy_rel=972.7310181,energy_abs=972.7310181 1707207183891338376
2024-02-06T08:13:12.123058883Z wem,topic=wem/wem/meter/values power=426.6087341,energy_rel=972.7310181,energy_abs=972.7310181 1707207184927391211
2024-02-06T08:13:12.123099109Z wem,topic=wem/wem/meter/values power=425.9482727,energy_rel=972.7310181,energy_abs=972.7310181 1707207185986620830
2024-02-06T08:13:12.123135800Z wem,topic=wem/wem/meter/values power=427.5354004,energy_rel=972.7310181,energy_abs=972.7310181 1707207187000881390
2024-02-06T08:13:12.123170471Z wem,topic=wem/wem/meter/values power=427.1164246,energy_rel=972.7310181,energy_abs=972.7310181 1707207188036245674
2024-02-06T08:13:12.123214472Z wem,topic=wem/wem/meter/values power=424.7435608,energy_rel=972.7310181,energy_abs=972.7319946 1707207189071575564
2024-02-06T08:13:12.123249322Z wem,topic=wem/wem/meter/values power=423.9685974,energy_rel=972.7319946,energy_abs=972.7319946 1707207190131060875
2024-02-06T08:13:22.122748061Z wem,topic=wem/wem/meter/values power=430.3375854,energy_rel=972.7319946,energy_abs=972.7319946 1707207192177208342
2024-02-06T08:13:22.123223886Z wem,topic=wem/wem/meter/values power=422.6810608,energy_rel=972.7319946,energy_abs=972.7319946 1707207193212569712
2024-02-06T08:13:22.123278877Z wem,topic=wem/wem/meter/values power=421.0473938,energy_rel=972.7319946,energy_abs=972.7319946 1707207194247818417
2024-02-06T08:13:22.123315474Z wem,topic=wem/wem/meter/values energy_abs=972.7319946,power=420.3343506,energy_rel=972.7319946 1707207195283237339
2024-02-06T08:13:22.123349200Z wem,topic=wem/wem/meter/values power=421.4379578,energy_rel=972.7319946,energy_abs=972.7319946 1707207196342997542
2024-02-06T08:13:22.123381424Z wem,topic=wem/wem/meter/values energy_rel=972.7319946,energy_abs=972.7319946,power=423.6992188 1707207197357424116
2024-02-06T08:13:22.123414767Z wem,topic=wem/wem/meter/values power=424.8660278,energy_rel=972.7329712,energy_abs=972.7329712 1707207198393429672
2024-02-06T08:13:22.123454941Z wem,topic=wem/wem/meter/values energy_abs=972.7329712,power=424.6819458,energy_rel=972.7329712 1707207199429150760
2024-02-06T08:13:22.123549634Z wem,topic=wem/wem/meter/values energy_rel=972.7329712,energy_abs=972.7329712,power=420.5588379 1707207200465024265
2024-02-06T08:13:22.123585251Z wem,topic=wem/wem/meter/values energy_rel=972.7329712,energy_abs=972.7329712,power=415.8323975 1707207201523242312
2024-02-06T08:13:32.123180770Z wem,topic=wem/wem/meter/values power=426.8390503,energy_rel=972.7329712,energy_abs=972.7329712 1707207202537644284
2024-02-06T08:13:32.123677562Z wem,topic=wem/wem/meter/values energy_abs=972.7329712,power=421.01651,energy_rel=972.7329712 1707207203573358943
2024-02-06T08:13:32.123723401Z wem,topic=wem/wem/meter/values power=416.7814636,energy_rel=972.7329712,energy_abs=972.7329712 1707207204610160241
2024-02-06T08:13:32.123760098Z wem,topic=wem/wem/meter/values power=420.6897278,energy_rel=972.7329712,energy_abs=972.7329712 1707207205646034028
2024-02-06T08:13:32.123794237Z wem,topic=wem/wem/meter/values power=419.6331787,energy_rel=972.7340088,energy_abs=972.7340088 1707207206681518585
2024-02-06T08:13:32.123829879Z wem,topic=wem/wem/meter/values power=415.3311768,energy_rel=972.7340088,energy_abs=972.7340088 1707207207718084069
2024-02-06T08:13:32.123866176Z wem,topic=wem/wem/meter/values energy_rel=972.7340088,energy_abs=972.7340088,power=415.428009 1707207208753513001
2024-02-06T08:13:32.123898355Z wem,topic=wem/wem/meter/values power=414.7074585,energy_rel=972.7340088,energy_abs=972.7340088 1707207209788771615
2024-02-06T08:13:32.123933994Z wem,topic=wem/wem/meter/values power=411.2091064,energy_rel=972.7340088,energy_abs=972.7340088 1707207210824789896
2024-02-06T08:13:32.123966139Z wem,topic=wem/wem/meter/values energy_abs=972.7340088,power=411.1620178,energy_rel=972.7340088 1707207211860159149
2024-02-06T08:13:42.123746284Z wem,topic=wem/wem/meter/values energy_rel=972.7340088,energy_abs=972.7340088,power=410.4578247 1707207212895390624
2024-02-06T08:13:42.126001025Z wem,topic=wem/wem/meter/values energy_abs=972.7340088,power=407.5687256,energy_rel=972.7340088 1707207213931673652
2024-02-06T08:13:42.126052882Z wem,topic=wem/wem/meter/values power=414.9447937,energy_rel=972.7349854,energy_abs=972.7349854 1707207214967648094
2024-02-06T08:13:42.126099405Z wem,topic=wem/wem/meter/values power=410.2969666,energy_rel=972.7349854,energy_abs=972.7349854 1707207216003933323
2024-02-06T08:13:42.126133729Z wem,topic=wem/wem/meter/values power=410.2279968,energy_rel=972.7349854,energy_abs=972.7349854 1707207217063016885
2024-02-06T08:13:42.126168214Z wem,topic=wem/wem/meter/values power=412.7409668,energy_rel=972.7349854,energy_abs=972.7349854 1707207218077137351
2024-02-06T08:13:42.126214774Z wem,topic=wem/wem/meter/values power=406.5802612,energy_rel=972.7349854,energy_abs=972.7349854 1707207219112634394
2024-02-06T08:13:42.126250550Z wem,topic=wem/wem/meter/values energy_abs=972.7349854,power=405.6170654,energy_rel=972.7349854 1707207220149143001
2024-02-06T08:13:42.126283837Z wem,topic=wem/wem/meter/values power=409.4949951,energy_rel=972.7349854,energy_abs=972.7349854 1707207221184663857
2024-02-06T08:13:52.124589920Z wem,topic=wem/wem/meter/values energy_abs=972.7349854,power=407.7871704,energy_rel=972.7349854 1707207222220569080
2024-02-06T08:13:52.125024497Z freezer,topic=tele/freezer/SENSOR ENERGY_Power=44,ENERGY_Voltage=221,ENERGY_Yesterday=0.561,ENERGY_ApparentPower=64,ENERGY_Total=9.235,ENERGY_Period=1,ENERGY_ReactivePower=46,ENERGY_Factor=0.69,ENERGY_Current=0.288,ENERGY_Today=0.215 1707207222849011160
2024-02-06T08:13:52.125093395Z wem,topic=wem/wem/meter/values power=413.2203369,energy_rel=972.7349854,energy_abs=972.7349854 1707207223279437264
2024-02-06T08:13:52.125200180Z wem,topic=wem/wem/meter/values energy_abs=972.7360229,power=410.2542419,energy_rel=972.7349854 1707207224294095680
2024-02-06T08:13:52.125237575Z wem,topic=wem/wem/meter/values power=410.7394409,energy_rel=972.7360229,energy_abs=972.7360229 1707207225329652556
2024-02-06T08:13:52.125275782Z wem,topic=wem/wem/meter/values power=404.842926,energy_rel=972.7360229,energy_abs=972.7360229 1707207226388704120
2024-02-06T08:13:52.125309126Z wem,topic=wem/wem/meter/values power=408.7755737,energy_rel=972.7360229,energy_abs=972.7360229 1707207227402553229
2024-02-06T08:13:52.125341400Z wem,topic=wem/wem/meter/values energy_abs=972.7360229,power=410.180603,energy_rel=972.7360229 1707207228438563571
2024-02-06T08:13:52.125373190Z wem,topic=wem/wem/meter/values energy_abs=972.7360229,power=406.0344849,energy_rel=972.7360229 1707207229473713712
2024-02-06T08:13:52.125404886Z wem,topic=wem/wem/meter/values power=407.6040649,energy_rel=972.7360229,energy_abs=972.7360229 1707207230534362319
2024-02-06T08:13:52.125436127Z wem,topic=wem/wem/meter/values power=407.2220154,energy_rel=972.7360229,energy_abs=972.7369995 1707207231547979033
2024-02-06T08:14:02.124719702Z wem,topic=wem/wem/meter/values power=407.1228638,energy_rel=972.7369995,energy_abs=972.7369995 1707207232583713179
2024-02-06T08:14:02.125206391Z wem,topic=wem/wem/meter/values energy_rel=972.7369995,energy_abs=972.7369995,power=406.6485596 1707207233618872262
2024-02-06T08:14:02.125251925Z wem,topic=wem/wem/meter/values power=403.6655884,energy_rel=972.7369995,energy_abs=972.7369995 1707207234654836904
2024-02-06T08:14:02.125291541Z wem,topic=wem/wem/meter/values energy_rel=972.7369995,energy_abs=972.7369995,power=401.8453064 1707207235690788973
2024-02-06T08:14:02.125330440Z wem,topic=wem/wem/meter/values energy_rel=972.7369995,energy_abs=972.7369995,power=402.4985962 1707207236726932982
2024-02-06T08:14:02.125365266Z wem,topic=wem/wem/meter/values power=405.1867676,energy_rel=972.7369995,energy_abs=972.7369995 1707207237762923886
2024-02-06T08:14:02.125398955Z wem,topic=wem/wem/meter/values energy_abs=972.7369995,power=402.7385864,energy_rel=972.7369995 1707207238798805781
2024-02-06T08:14:02.125430866Z wem,topic=wem/wem/meter/values power=405.1834412,energy_rel=972.7369995,energy_abs=972.7369995 1707207239833857137
2024-02-06T08:14:02.125468338Z wr,name=SMA,slave_id=3,type=input_register DC_amp_s=134,DC_volt_s=52997,DC_watt_s=71,AC_watt=93,DC_amp_n=101,DC_volt_n=49224,DC_watt_n=50 1707207240000000000
2024-02-06T08:14:02.125519185Z wem,topic=wem/wem/meter/values power=400.1495361,energy_rel=972.7369995,energy_abs=972.7369995 1707207240868888995
2024-02-06T08:14:02.125555515Z wem,topic=wem/wem/meter/values power=402.6314392,energy_rel=972.7379761,energy_abs=972.7379761 1707207241908525144
2024-02-06T08:14:12.126824074Z wem,topic=wem/wem/meter/values power=406.9479675,energy_rel=972.7379761,energy_abs=972.7379761 1707207242944103011
2024-02-06T08:14:12.127316084Z wem,topic=wem/wem/meter/values energy_abs=972.7379761,power=403.5462341,energy_rel=972.7379761 1707207243979954642
2024-02-06T08:14:12.127362139Z wem,topic=wem/wem/meter/values power=403.677948,energy_rel=972.7379761,energy_abs=972.7379761 1707207245014828143
2024-02-06T08:14:12.127401921Z wem,topic=wem/wem/meter/values power=404.5191345,energy_rel=972.7379761,energy_abs=972.7379761 1707207246049700608
2024-02-06T08:14:12.127436452Z wem,topic=wem/wem/meter/values energy_abs=972.7379761,power=406.7151184,energy_rel=972.7379761 1707207247084763871
2024-02-06T08:14:12.127538431Z wem,topic=wem/wem/meter/values power=403.7931213,energy_rel=972.7379761,energy_abs=972.7379761 1707207248120819011
2024-02-06T08:14:12.127572964Z wem,topic=wem/wem/meter/values power=403.2939148,energy_rel=972.7379761,energy_abs=972.7379761 1707207249156854117
2024-02-06T08:14:12.127613019Z wem,topic=wem/wem/meter/values power=403.0163269,energy_rel=972.7379761,energy_abs=972.7379761 1707207250191834945
2024-02-06T08:14:12.127645269Z wem,topic=wem/wem/meter/values power=403.2032471,energy_rel=972.7390137,energy_abs=972.7390137 1707207251228686265
2024-02-06T08:14:22.125535862Z wem,topic=wem/wem/meter/values power=405.7171936,energy_rel=972.7390137,energy_abs=972.7390137 1707207252263883111
2024-02-06T08:14:22.125986826Z wem,topic=wem/wem/meter/values power=405.0045166,energy_rel=972.7390137,energy_abs=972.7390137 1707207253300116063
2024-02-06T08:14:22.126029790Z wem,topic=wem/wem/meter/values power=416.5310669,energy_rel=972.7390137,energy_abs=972.7390137 1707207254335941856
2024-02-06T08:14:22.126068504Z wem,topic=wem/wem/meter/values energy_rel=972.7390137,energy_abs=972.7390137,power=466.3877258 1707207255394238772
2024-02-06T08:14:22.126111806Z wem,topic=wem/wem/meter/values power=364.8630066,energy_rel=972.7390137,energy_abs=972.7390137 1707207256407878065
2024-02-06T08:14:22.126147926Z wem,topic=wem/wem/meter/values power=420.793335,energy_rel=972.7390137,energy_abs=972.7390137 1707207257471244251
2024-02-06T08:14:22.126181263Z wem,topic=wem/wem/meter/values power=480.932251,energy_rel=972.7399902,energy_abs=972.7399902 1707207258487752104
2024-02-06T08:14:22.126225113Z wem,topic=wem/wem/meter/values energy_rel=972.7399902,energy_abs=972.7399902,power=477.9319458 1707207259545236945
2024-02-06T08:14:22.126260126Z wem,topic=wem/wem/meter/values power=479.5367432,energy_rel=972.7399902,energy_abs=972.7399902 1707207260559792189
2024-02-06T08:14:22.126292837Z wem,topic=wem/wem/meter/values energy_abs=972.7399902,power=484.2618713,energy_rel=972.7399902 1707207261595464408
2024-02-06T08:14:32.126241435Z wem,topic=wem/wem/meter/values energy_rel=972.7399902,energy_abs=972.7399902,power=487.645752 1707207262653172072
2024-02-06T08:14:32.126693092Z wem,topic=wem/wem/meter/values power=485.7137756,energy_rel=972.7399902,energy_abs=972.7399902 1707207263666908936
2024-02-06T08:14:32.126736229Z wem,topic=wem/wem/meter/values energy_rel=972.7399902,energy_abs=972.7399902,power=491.3535461 1707207264702935656
2024-02-06T08:14:32.126785564Z wem,topic=wem/wem/meter/values energy_abs=972.7399902,power=506.3872986,energy_rel=972.7399902 1707207265739397284
2024-02-06T08:14:32.126840409Z wem,topic=wem/wem/meter/values power=500.0916443,energy_rel=972.7410278,energy_abs=972.7410278 1707207266775140215
2024-02-06T08:14:32.126882167Z wem,topic=wem/wem/meter/values energy_abs=972.7410278,power=477.176178,energy_rel=972.7410278 1707207267811533178
2024-02-06T08:14:32.126916476Z wem,topic=wem/wem/meter/values power=440.304718,energy_rel=972.7410278,energy_abs=972.7410278 1707207268870633876
2024-02-06T08:14:32.126949618Z wem,topic=wem/wem/meter/values energy_rel=972.7410278,energy_abs=972.7410278,power=439.1445618 1707207269885800292
2024-02-06T08:14:32.126985110Z wem,topic=wem/wem/meter/values power=438.3282471,energy_rel=972.7410278,energy_abs=972.7410278 1707207270943508091
2024-02-06T08:14:32.127018668Z wem,topic=wem/wem/meter/values power=447.3531799,energy_rel=972.7410278,energy_abs=972.7410278 1707207271958677292
2024-02-06T08:14:42.127293471Z wem,topic=wem/wem/meter/values energy_abs=972.7410278,power=442.5587769,energy_rel=972.7410278 1707207272994806631
2024-02-06T08:14:42.127778359Z wem,topic=wem/wem/meter/values power=447.186615,energy_rel=972.7410278,energy_abs=972.7410278 1707207274030824218
2024-02-06T08:14:42.127828659Z wem,topic=wem/wem/meter/values energy_rel=972.7410278,energy_abs=972.7420044,power=440.920929 1707207275066991041
2024-02-06T08:14:42.127866666Z wem,topic=wem/wem/meter/values power=442.8806152,energy_rel=972.7420044,energy_abs=972.7420044 1707207276102811303
2024-02-06T08:14:42.127903609Z wem,topic=wem/wem/meter/values energy_abs=972.7420044,power=447.1797485,energy_rel=972.7420044 1707207277139430078
2024-02-06T08:14:42.127935909Z wem,topic=wem/wem/meter/values energy_rel=972.7420044,energy_abs=972.7420044,power=441.0249023 1707207278175401686
2024-02-06T08:14:42.127967782Z wem,topic=wem/wem/meter/values power=443.958313,energy_rel=972.7420044,energy_abs=972.7420044 1707207279211899626
2024-02-06T08:14:42.127999949Z wem,topic=wem/wem/meter/values power=445.6430664,energy_rel=972.7420044,energy_abs=972.7420044 1707207280281474792
2024-02-06T08:14:42.128032096Z wem,topic=wem/wem/meter/values power=446.7321472,energy_rel=972.7420044,energy_abs=972.7420044 1707207281308859414
2024-02-06T08:14:52.127783759Z wem,topic=wem/wem/meter/values energy_rel=972.7420044,energy_abs=972.7420044,power=448.7087708 1707207282323803566
2024-02-06T08:14:52.128252055Z freezer,topic=tele/freezer/SENSOR ENERGY_ApparentPower=64,ENERGY_Yesterday=0.561,ENERGY_Period=1,ENERGY_Voltage=221,ENERGY_Current=0.29,ENERGY_Today=0.216,ENERGY_Power=44,ENERGY_ReactivePower=47,ENERGY_Factor=0.69,ENERGY_Total=9.236 1707207282860136550
2024-02-06T08:14:52.128320425Z wem,topic=wem/wem/meter/values power=452.7224121,energy_rel=972.7420044,energy_abs=972.742981 1707207283360060669
2024-02-06T08:14:52.128358386Z wem,topic=wem/wem/meter/values power=454.9103394,energy_rel=972.742981,energy_abs=972.742981 1707207284420242300
