Missing tag values
I created a small conf file that runs a bash script.
Inside the script I run a basic command as follows:
netstat -tulnp.
I have placed the bash file inside /etc/telegraf/scripts folder.
When I run the test command Incan see the correct output as follows:
openport,pid=123,program=java TEXT=8081
however I am not seeing values for taga pid and program in the Influx DB.
Influx - 2.2
Telegraf - 1.23.1
OS - Ubuntu 20.04
Would appreciate sone insight as to what and how I can check to debug why the pid and program tags are not showing in the influxdb.
Thanks !!
Hi @utsukprani
It would help to see the snippet of Telegraf conf code you are using to do this. You can set debug = true in the [agent] section which might show more details during runtime.
hi @phill thanks for your reply.
i updated telegraf.conf to have debug = true.
however can you specify where can i see logs ?
i am on Ubuntu 20.04.4 LTS version.
my conf file which is in telegraf.d looks like as follows:
[[inputs.exec]]
commands = [“/etc/telegraf/scripts/getOpenPorts.sh”]
timeout = “60s”
data_format = “influx”
@utsukprani
I run in a docker container and this is a sample of what I see on the terminal (stdout)
2022-07-02T00:07:05Z I! Using config file: /etc/telegraf/telegraf.conf
2022-07-02T00:07:05Z I! Starting Telegraf 1.23.0
2022-07-02T00:07:05Z I! Loaded inputs: http
2022-07-02T00:07:05Z I! Loaded aggregators:
2022-07-02T00:07:05Z I! Loaded processors:
2022-07-02T00:07:05Z I! Loaded outputs: file
2022-07-02T00:07:05Z I! Tags enabled: host=ad61a2f4ac4c
2022-07-02T00:07:05Z I! [agent] Config: Interval:10m0s, Quiet:false, Hostname:"ad61a2f4ac4c", Flush Interval:2m0s
2022-07-02T00:07:05Z D! [agent] Initializing plugins
2022-07-02T00:07:05Z D! [agent] Connecting outputs
2022-07-02T00:07:05Z D! [agent] Attempting connection to [outputs.file]
2022-07-02T00:07:05Z D! [agent] Successfully connected to outputs.file
2022-07-02T00:07:05Z D! [agent] Starting service inputs
My output plug-in is enabled as follows:
[[outputs.file]]
  files = ["stdout"]
