I’m using open source verison of InfluxDB on Windows with default settings. Tried 1.6.4 and 1.7.1
When I specify any retention policy then default, the data is not stored.
For test purposes I’ve created two identical retention policies - default and non_default:
show retention policies
name duration shardGroupDuration replicaN default
default 168h0m0s 24h0m0s 1 true
non_default 168h0m0s 24h0m0s 1 false
When I’m posting data with non_default retencion policy nothing happens. Server returns success but there is no data in metrics.
$ curl -i -XPOST " http://influx1:8086/write?db=test&rp=non_default" --data-binary ‘TestViaHttp,mytag=a myfield=90’
When I’m posting data with default retencion policy it is inserted successfully.
$ curl -i -XPOST " http://influx1:8086/write?db=test&rp=default" --data-binary ‘TestViaHttp,mytag=a myfield=90’
Does anyone have an idea how to fix this?
