Hi, I’m using telegraf v1.17 and seeing the following error when using the aggregators.merge plugin:
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-26 15:28:22.21403368 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-26 15:28:24.214026383 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-06 09:47:23.200776613 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-06 09:47:23.960186435 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-26 15:28:07.555448454 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
2021-01-26T20:28:32Z D! [aggregators.merge] Metric is outside aggregation window; discarding. 2021-01-06 09:54:25.737673279 -0500 EST: m: 2021-01-26 15:28:30 -0500 EST e: 2021-01-26 15:29:00 -0500 EST g: 0s
Data is coming from a network device and I would like to merge multiple data points for a single router and interface together.
Currently, the data is flowing in like this:
Click To View Router Data
"fields": {
"out_broadcast_pkts": 0,
"out_discards": 0,
"out_errors": 0
"name": "interfaces",
"tags": {
"host": "lab-aar-deployment-745698dc99-5wml9-telegraf-agent",
"interface-name": "Ethernet10",
"path": "/interfaces/interface/state/counters",
"source": "router101.mgt.net"
"timestamp": 1609944428
"fields": {
"out_multicast_pkts": 265842,
"out_octets": 62786069
"tags": {
"timestamp": 1611690672
I would like the data to come in like this:
Click To View Desired Data
“fields”: {
“out_broadcast_pkts”: 0,
“out_discards”: 0,
“out_errors”: 0,
“out_multicast_pkts”: 265842,
“out_octets”: 62786069
“name”: “interfaces”,
“tags”: {
“host”: “lab-aar-deployment-745698dc99-5wml9-telegraf-agent”,
“interface-name”: “Ethernet10”,
“path”: “/interfaces/interface/state/counters”,
“source”: “router101.mgt.net”
“timestamp”: 1609944428
Thank you.
