When specifying metric_batch_size does telegraf add any metadata to batch output to indicate batches. For instance, i have 2000 metrics with batch size of 1000. When metrics are sent from output plugin, i believe it will send the metrics in 2 batches (assuming it does not exceed the buffer limit). how can i know the number of batches.
Hello @rahav_jv
No telegraf does not add any metadata to the output, it does not have:
- Which batch a metric came from
- The batch number
- Batch grouping IDs
telegraf batches internally and then writes a flat list of metrics to the output. idk if @skartikey knows a way to include this.
What is your use case/context? Maybe this is an xy problem or we can help in another way.
