I have a question about measurements and fields when it comes to planning the data layout of the database.
My use case is that I have a device that outputs thousands of time series and I am not quite sure whether it makes more sense to store the device as a measurement and all the time series as separate field keys or if I’d rather store each time series as a separate measurement. So basically the question is should I store it according to option A:
measurement: device1
field_key: TS1
field_key: TS2
field_key: TS3
or according to option B:
measurement: TS1
field_key: TS1
measurement: TS2
field_key: TS2
measurement: TS3
field_key: TS3
I have found a few resources that discuss this distinction but I am still not sure if I have understood all the implications of the different options. In this post: Query regarding cardinality. Empty field vs multiple measurements, the conclusion basically seems to be that when it comes to the series cardinality it really does not make any difference whether option A or B is used but “but if you plan on performing queries or calculations that combine different devices and sensors, it’ll be best to keep those in the same measurement”.
Over here: database schema - InfluxDB : single or multiple measurement - Stack Overflow, the same question is discussed with partly the same conclusions. In addition, the accepted answer states that if one measurement contains several fields, values has to be written to every field once one field changes. If this is the case, it certainly is a drawback in my case. When I made some testing, however, this does not seem to be the case. Could someone confirm that writing a field value to one field key under a certain measurement will not force me to write field values to all the field keys under the given measurement? Maybe this has been different before?
in the Data Layout and Schema Design Best Practices for InfluxDB blog post (Data Layout and Schema Design Best Practices for InfluxDB | InfluxData), the same thing about keeping time series that logically belong together in the same measurement is a good idea because it makes queries less resource intensive. Additionally, at the very end of the article, a few “common schema design mistakes that lead to runaway cardinality” are listed. One of the listed mistakes seems to suggest that splitting up the time series into too many measurements is a bad idea:
Unfortunately, I am not able to make sense of this example. Could someone, maybe @Anaisdg elaborate a little more on this potential misstake?
In addition to the questions that I already asked, there is one question that I have not really been able to find a good answer to: What would be the drawbacks of design option A as opposed to design option B as presented above? To explain TS1,TS2,TS3,… a little more in detail, some of them may be related but the relationships are not necessarily known when inserting them into the database, thus the criteria about keeping time series that may be combined under the same measurement is not so easy to apply in this case. In addition, that criteria only tells something about when data is good to keep under the same measurement but it does not seem to say the opposite (i.e. if the data don’t belong together, will I get some advantages by splitting it across several measurements?).
