Hi
Need to get max count of specific field in last 30 minutes.
What is appropriate query for this?
Hi
Are you using Flux or InfluxQL?
@grant1 Flux.
FYI: I group by myfield each 1s and it has specific value in each second,now need to find maximum value of last 30 min that group by each 1s.
example:
00:01:00 50
00:01:01 100
00:01:02 2
00:01:03 101
00:01:04 90
00:01:05 56
expected output: 101
here is what i try:
http://192.168.1.1:8086/query?pretty=true&q=SELECT+MAX(count)+FROM+(SELECT+count(myfield)+AS+count+FROM+mymeasure) WHERE time > now() - 30m GROUP BY time(1s) &db=mydb
You stated that you are using Flux, but the query that you showed is InfluxQL. Can you please clarify which language you are using?
