I’m trying to use logstash geoip filter to send data about location of IP address to InfluxDB via InfluxDB output plugin.
My logstash conf file is:
input {
file {
path => "/root/geoip_test.txt"
start_position => "beginning"
filter {
geoip {
source => "message"
fields => ["latitude", "longitude"]
output {
stdout {codec => rubydebug}
influxdb {
host => "localhost"
port => 8086
db => "metrics"
measurement => "geoip_test"
codec => "json"
use_event_fields_for_data_points => true
geoip_test.txt file contains only one IP address:
14.143.35.10
Output with error I receive is:
[2020-09-07T12:26:26,696][INFO ][logstash.agent ] Successfully started Logstash API endpoint {:port=>9600}
"geoip" => {
"latitude" => 12.9771,
"longitude" => 77.5871
"message" => "14.143.35.10",
"path" => "/root/geoip_test.txt",
"@timestamp" => 2020-09-07T10:26:33.963Z,
"host" => "test",
"@version" => "1"
[2020-09-07T12:26:34,942][WARN ][logstash.outputs.influxdb][main][941178b6897abb80f9a5f7654e5e62ba752d5e20b68781bc62b466e489c2ce56] Non recoverable exception while writing to InfluxDB {:exception=>#<InfluxDB::Error: {"error":"unable to parse 'geoip_test,host=test geoip={\"latitude\"=\u003e12.9771, \"longitude\"=\u003e77.5871},path=\"/root/geoip_test.txt\" 1599474393963': invalid boolean"}
I think geoip filter generates some boolean field which InfluxDB is not able to work with.
Does anyone have any idea what to do with that? Is it possible to set up geoip filter in some way so it wouldn’t generate anything but lon and lat fields?
Any help is really appreciated!
