i need to join two tables together where i use the new join functionality.
the join works until the data table has more than x entrys. so my question is, is there any limit on using the join function? If i put limit 1000 to the data table it works, if i put in limit 1001 it fails with “panic: arrow/array: index out of range”
with best regards
this are my datas:
| tableMETADATA | _timeNO GROUPDATETIME:RFC3339 | NameNO GROUPSTRING | topicGROUPSTRING |
| 0 | 2022-01-01T00:00:00.000Z | Waermepumpe | GERNER/Teststation/Zaehler/1 |
| 1 | 2022-01-01T00:00:00.000Z | Elektroauto | GERNER/Teststation/Zaehler/2 |
| 2 | 2022-01-01T00:00:00.000Z | Netz Export | GERNER/Teststation/Zaehler/Netz_Export |
| tableDATA | _valueNO GROUPDOUBLE | _timeNO GROUPDATETIME:RFC3339 | topicGROUPSTRING |
| 0 | 10 | 2022-11-28T10:53:10.000Z | GERNER/Teststation/Zaehler/1 |
| 0 | 10 | 2022-11-28T10:57:00.000Z | GERNER/Teststation/Zaehler/1 |
| 0 | 0 | 2022-11-28T11:00:50.000Z | GERNER/Teststation/Zaehler/1 |
| 0 | 10 | 2022-11-28T11:04:40.000Z | GERNER/Teststation/Zaehler/1 |
this should be archived:
| tableENDTABELLE | _valueNO GROUPDOUBLE | _timeNO GROUPDATETIME:RFC3339 | NameNO GROUPSTRING | topicGROUPSTRING |
| 0 | 10 | 2022-11-28T10:53:10.000Z | Waermepumpe | GERNER/Teststation/Zaehler/1 |
| 0 | 10 | 2022-11-28T10:57:00.000Z | Waermepumpe | GERNER/Teststation/Zaehler/1 |
| 0 | 0 | 2022-11-28T11:00:50.000Z | Waermepumpe | GERNER/Teststation/Zaehler/1 |
| 0 | 10 | 2022-11-28T11:04:40.000Z | Waermepumpe | GERNER/Teststation/Zaehler/1 |
this is my query:
import “strings”
import j “join”
metadata=from(bucket: “data”)
|> range(start: 2021-12-31T23:00:00.000Z, stop: 2022-01-01T22:00:00.000Z)
|> filter(fn: (r) => r[“topic”] =~ /GERNER/Teststation/)
|> filter(fn: (r) => r[“topic”] =~ /Zaehler/)
|> filter(fn: (r) => r[“_measurement”] == “Bezeichnung”)
|> rename(columns: {_value: “Name”})
|> drop(columns: [“db”,“_start”,“_field”,“_stop”,“_measurement”])
//|> yield(name: “metadata”)
|> filter(fn: (r) => r[“_measurement”] == “WH”)
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> map(fn: (r) => ({ r with _value:r._value * 10.}))
|> difference(nonNegative: true)
|> limit(n:1000, offset: 0)
//|> yield(name: “data”)
jointable=j.right(
left: data,
right: metadata,
on: (l, r) => l.topic == r.topic,
as: (l, r) => ({l with “Name”: r[“Name”]}),
|> yield(name: “Endtabelle”)
