Hello all,
I’m going crazy with the Influx.
I get a Daily_Energy_Yield value from a SmartMeter. I want to retrieve this value per day, but always the last value greater than 0.
from(bucket: "my-bucket")
|> range(start: -10d, stop: now())
|> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Huawei.Inverter.Daily_Energy_Yield")
|> filter(fn: (r) => r["_field"] == "value")
|> aggregateWindow(every: 1d, fn: last, createEmpty: false)
|> yield(name: "last")
This is my raw data.
Finally, I would like to display it like this.
Thanks for help
… just filter value bigger than zero
another tip, if you use relative time as start, you dont need to type now() it is implicit that is relative to now
matze1708:
|> range(start: -10d)
|> filter(fn: (r) => r["_value"] > 0 )
|> yield(name: "last")
Thank you for the answer,
I’ve adopted it as it is.
But I only get 2 values from last month and one that is current from today.
