Kapacitor to be less verbose
Dear all,
I would like kapacitor to be less verbose.
I would be happy with triggering alerts only when states change in the bad way, or not triggering OK alerts.
Any of that is possible ?
Would you suggest other solutions ?
Regards,
Colin
I’d suggest looking through the GitHub Issues for Kapacitor and see if any of them match what you’re looking for. If not, feel free to open one with a detailed message about the feature you’d like.
We might be able to find an alternative that works for you if you don’t want to do that. What exactly are you trying to do?
