I have a simple measurement in stream:
{"series":[{"name":"maintenance","tags":{"env":"pre","host":"hostname"},"columns":["time","value"],"values":[["2019-01-28T17:27:40Z","localhost.localdomain"]]}]}
The other is cpu measurement. When I join two nodes I am loosing my values except one value.
// Dataframe
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groups)
.where(whereFilter)
|window()
.period(period)
.every(every)
.align()
|join(maintlock)
.as('m1','m2')
.tolerance(1s)
.fill('none')
|eval(lambda: 100.0 - "m1.usage_idle")
.as('cpuUsed')
|mean('cpuUsed')
.as('stat')
|httpOut('outdata')
So the JoinNode is destroying my values, only one value left from random host. How can I join my cpu metrics and my simple custom measurement AND save all values from all hosts I have in this stream?
