Hello Community,
I have installed Grafana Plugin in my Thinger.io instance in which I have InfluxDB as default datasource. I now want to perform join queries between two buckets and show that data in Grafana Panel. But I am not able to fire any Join queries. Kindly help me.
Hello @Technically_Nerd,
Welcome!
What have you tried so far? And what does your data look like?
I have data constantly coming from my sensors every 15 minutes. I have tried joining 2 buckets in Thinger. But actually I found out what was the problem. I am not able to switch to Flux Query language inside of Thinger.
i wouldn’t expect you to be able to use flux with thinger because it sits behind influxdata as it just manages your fleet. What version of InfluxDB are you using? If you’re using 1.8+ then you can use joins. I would recommend upgrading to 2.x though so you don’t have to go through the trouble of enabling flux like you would have to do with 1.8
