I’ve been using the java client library to make write/read queries to influx. However, I found this problem when trying to sort data using the sort() method.
For context, my app is a chatbot that writes recognized messages/responses into the database, which works perfectly fine. On the other hand, I read the data to create visualizations. I do use this flux query to do so:
from(bucket: "xatbot")
|> range(start: 2018-05-22T23:30:00Z, stop: now())
|> filter(fn:(r) => r._measurement == "intent" and r.bot_id == "xatkitBot" and r.session_id == "sessionId")
|> pivot(columnKey: ["_field"], rowKey: ["_time"], valueColumn: "_value")
|> group()
|> sort(columns: ["_time"])
This works perfectly fine in the localhost:xxxx instance of influx (the dashboard influxdata provides) and I get the desired data ordered in the desired way (timestamp). Making the same query in the APP does return the data without sorting for some reason, sample output:
02:57:10.588 [pool-3-thread-1] INFO - ----------------------------------------------------------------------------
02:57:10.589 [pool-3-thread-1] INFO - 2020-06-04T12:58:07.164Z
02:57:10.589 [pool-3-thread-1] INFO - 2020-06-04T12:58:03.949Z
02:57:10.589 [pool-3-thread-1] INFO - ----------------------------------------------------------------------------
02:57:10.590 [pool-3-thread-1] INFO - 2020-06-18T14:04:14.495Z
02:57:10.590 [pool-3-thread-1] INFO - 2020-06-18T14:03:45.277Z
02:57:10.591 [pool-3-thread-1] INFO - 2020-06-18T14:03:47.713Z
02:57:10.591 [pool-3-thread-1] INFO - ----------------------------------------------------------------------------
02:57:10.591 [pool-3-thread-1] INFO - 2020-06-11T13:07:24.434Z
02:57:10.592 [pool-3-thread-1] INFO - 2020-06-11T13:07:22.559Z
02:57:10.592 [pool-3-thread-1] INFO - ----------------------------------------------------------------------------
02:57:10.592 [pool-3-thread-1] INFO - 2020-05-26T14:18:01.286Z
02:57:10.593 [pool-3-thread-1] INFO - 2020-05-26T14:18:16.674Z
02:57:10.593 [pool-3-thread-1] INFO - ----------------------------------------------------------------------------
02:57:10.593 [pool-3-thread-1] INFO - 2020-05-25T14:01:55.883Z
02:57:10.594 [pool-3-thread-1] INFO - 2020-05-25T14:01:39.396Z
02:57:10.594 [pool-3-thread-1] INFO - 2020-05-25T14:01:50.796Z
The lines with “-----------” means they are different session in my bot, sort should be happening inside each session.
The query in the java app is created this way:
String query = "from(bucket: \"xatbot\")
|> filter(fn:(r) => r._measurement == \"intent\" and r.bot_id == \"xatkitBot\" and r.session_id == \"sessionId\")
|> pivot(columnKey: [\"_field\"], rowKey: [\"_time\"], valueColumn: \"_value\")
|> group()
|> sort(columns: [\"_time\"])" //I make different ones based on session_id field
//retrieves tables:
List<FluxTable> tables = db.getQueryApi().query(query);
List<FluxRecord> sessionData = tables.get(0).getRecords(); //I have only 1 table per query in this scenario.
Log.info("----------------------------------------------------------------------------");
for (FluxRecord sessionEntry : sessionData) {
Log.info(String.valueOf(sessionEntry.getValueByKey("_time")));
