2018-08-06T09:37:35Z W! DEPRECATED: The logparser plugin is deprecated in 1.8. Please use the tail
plugin with the grok data_format as a replacement.
2018-08-06T09:37:35Z E! Error parsing 2018/5/9.18:15:57 to time layout [2006/1/2,15:4:5]: parsing time
"2018/5/9.18:15:57" as "2006/1/2,15:4:5": cannot parse ".18:15:57" as ","
I guess I was using LogParser Grok and I think it has something to do with it.
This means that instead of using the logparser plugin (which is configured in the inputs.logparser.grok section of the config that you shared), you should be using the tail plugin, with the Grok data format.
Hi, I tested that and it works for me, but I have a problem with the changing measurement names. In Logparser Plugin I could define the measurement = Now all metrics go into the tail measurement.
With the processor.rename I can successfully rename the measurement, but what if I have different logfiles on a host and I want to rename the measurements for multiple logfiles ? Is that possible with 1.8 ?
