tfnick
December 1, 2021, 9:53am
1
I try to use http.post() in flux task and My steps are as follows:
Login in to influxdb on web
Create schedule task which call http.post()
Manual trigger the task
App receive the http request successed
Task triggered by influxdb allways are success, But the app can not receive the http request.
My question :
Manual success and received http request .
Influxdb schedule success but no http request received, Why?
Ps:
example event data send by another mock app, so the task can read/get event data successfully everytime.
Influxdb deployed in docker env.
Task script content
import “http”
option task = {name: “testtask”, every: 1h}
from(bucket: “systembucket”)
|> range(start: -task.every)
|> filter(fn: (r) => (r._measurement == “du2”))
|> filter(fn: (r) => (r._value > 10000))
|> aggregateWindow(every: 24h, fn: mean, createEmpty: false)
|> limit(n: 1, offset: 0)
|> map(fn: (r) =>
({r with status_code: http.post(url: "http://localhost:8088/api/v2/notify", headers: {"Content-Type": "application/json", Authorization: "Token faketoken"}, data: bytes(v: "{\"start\": 2021-01-11T22:00:00Z, \"stop\": 2021-01-12T00:00:00Z}"))}))
scott
December 1, 2021, 10:15pm
2
@tfnick The best thing here to do to troubleshoot would be to write the results of your task back to InfluxDB. It will include the response code of each sent request and should at least give you an idea if the requests are succeeding or failing.
import "http"
option task = {name: "testtask", every: 1h}
from(bucket: "systembucket")
|> filter(fn: (r) => (r._measurement == "du2"))
|> map(fn: (r) => ({r with
status_code: http.post(url: "http://localhost:8088/api/v2/notify", headers: {"Content-Type": "application/json", Authorization: "Token faketoken"}, data: bytes(v: "{\"start\": 2021-01-11T22:00:00Z, \"stop\": 2021-01-12T00:00:00Z}")),
_measurement: "notifications",
|> to(bucket: "example-bucket")
If you want the task to fail if the http.post() returns a non-200 repsonse, you can conditionally execute die() in a map() call.
Note: die() currently isn’t documented, but it will be soon.
import "http"
|> map(fn: (r) => {
check = if string(v: r.status_code) !~ /^2/ then die(msg: "http.post() received a ${r.status_code} status code") else r.status_code
return { r with status_code: check }
This will cause the task to fail and get logged to the InfluxDB task logs.
tfnick
December 2, 2021, 7:10am
3
@scott thank u I will try
tfnick
December 5, 2021, 2:09pm
4
@scott die function cannt help me locate the proplem.
The complete script is as follows.
import “json”
import “http”
option task = {name: “example_1m_xxx”, every: 1m, offset: 1s}
myEndpoint = http.endpoint(url: “http://192.168.1.199:8888/collect/api/notify ”)
from(bucket: “example”)
|> filter(fn: (r) => r._measurement == “cpu”)
|> aggregateWindow(every: task.every, fn: first, createEmpty: false)
|> duplicate(column: “_value”, as: “_value_price”)
|> derivative()
|> map(fn: (r) => ({r with _value: r._value / r._value_price}))
|> drop(columns: [“_value_price”])
|> group()
|> map(
fn: (r) => ({r with
jsonStr: string(
v: json.encode(
v: {
“_measurement”: r._measurement,
“exchange”: r.exchange,
“currency”: r.currency,
“_field”: r._field,
“_value”: r._value,
“_time”: r._time,
|> myEndpoint(
mapFn: (r) => ({headers: {Authorization: “Bearer mySuPerSecRetTokEn”, “Content-type”: “application/json”}, data: bytes(v: r.jsonStr)}),
|> map(
fn: (r) => {
check = if string(v: r.status_code) !~ /^2/ then die(msg: “http.post() received a ${r.status_code} status code”) else r.status_code
return {r with status_code: check}
scott
December 6, 2021, 5:11pm
5
@tfnick Ah, ok. I didn’t realize you were using http.endpoint(). That already appends the HTTP response code in the _sent column. Try this:
import "json"
import "http"
option task = {name: "example_1m_xxx", every: 1m, offset: 1s}
myEndpoint = http.endpoint(url: "http://192.168.1.199:8888/collect/api/notify")
from(bucket: "example")
|> filter(fn: (r) => r._measurement == "cpu")
|> duplicate(column: "_value", as: "_value_price")
|> derivative()
|> drop(columns: ["_value_price"])
|> group()
|> map(
fn: (r) => ({r with
jsonStr: string(
v: json.encode(
v: {
"_measurement": r._measurement,
"exchange": r.exchange,
"currency": r.currency,
"_field": r._field,
"_value": r._value,
"_time": r._time,
|> myEndpoint(mapFn: (r) => ({headers: {Authorization: "Bearer mySuPerSecRetTokEn", "Content-type": "application/json"}, data: bytes(v: r.jsonStr)}))()
|> map(
fn: (r) => {
check = if r._sent !~ /^2/ then die(msg: "http.post() received a ${r._sent} status code") else r._sent
return {r with _sent: check}
