Interpolate counter measurements (manual inputs)
Hi there,
I have some monthly counter measurements stored inside an InfluxDB instance, e.g. data like this (in line protocol):
readings,location=xyz,medium=Electricity,meter=mainMeter energy=13660 1625322660000000000
readings,location=xyz,medium=Electricity,meter=mainMeter energy=13810 1627839610000000000
These are monthly readings, not sharp to the beginning of a month (one is at 3rd of July, the other on 1st of August).
My goal it to interpolate these readings on a daily basis, so I stumbled upon the interpolate.linear function from Flux (https://docs.influxdata.com/influxdb/v2.0/reference/flux/stdlib/interpolate/linear/).
But the only output I can generate with my function returns me the two given data values from my input.
import "interpolate"
from(bucket: "ManualInput")
  |> filter(fn: (r) => r["_measurement"] == "readings")
  |> filter(fn: (r) => r["_field"] == "energy")
  |> interpolate.linear(every: 1d)
Am I missing something here? I’ve expected to have a linear interpolated value on each day… or is this not possible with Flux? (I’m using V 2.0.7)
Hello @ralphp,
Welcome! Thanks for your question.
The following worked for me:
import "array"
array.from(rows: [
  {_time: time(v: 1625322660000000000), _field: "exampleField", _value: 3, foo: "bar"},
  {_time: time(v: 1627839610000000000), _field: "exampleField", _value: 4, foo: "bar"}
  |> group(columns: ["_field", "foo"], mode:"by")
  |> toFloat()
Using your timestamps. It looks like there some requirements around the type “_value” type and what’s in the group key.
Hello @Anaisdg,
thanks for your answer. From your suggestion I’ve added the “toFloat()” line. This works for me now! I have to double check my datatype, but from the gui it looks like the raw data is of type double.
@ralphp,
Great! I’m happy it’s working for you now :slight_smile:
