I’m using sourceanalytics with iobroker. Unfortunately a configuration issue happens and I have to change some values in the influxdb.
select * from "sourceanalytix.0.mqtt__0__Gaszaehler__main__raw.currentYear.consumed.03_previousMonth";
time ack from q value
1705963932281000000 true system.adapter.influxdb.0 0 -12.39
value must be changed to 0.
What I understood influxdb does not now an “update” command but an insert with the same timestamp will update the value.
show field keys
name: sourceanalytix.0.mqtt__0__Gaszaehler__main__raw.currentYear.consumed.03_previousMonthfieldKey fieldType
ack boolean
from string
q float
value float
Based on these information an update like should work
insert "sourceanalytix.0.mqtt__0__Gaszaehler__main__raw.currentYear.consumed.03_previousMonth" ack=true,from="system.adapter.influxdb.0",q=0,value=0 1705963932281000000;
But i got the error
ERR: {"error":"unable to parse '\"sourceanalytix.0.mqtt__0__Gaszaehler__main__raw.currentYear.consumed.03_previousMonth\" ack=true,from=\"system.adapter.influxdb.0\",q=0,value=0 1705963932281000000;': bad timestamp"}
Could anyone give me a hint what the problem is? Many thanks
