I wanted to use apache kafka as input for telegraf. I am running docker containers. Docker image is from - GitHub - wurstmeister/kafka-docker: Dockerfile for Apache Kafka
This is my docker-compose file:
version: ‘3’
services:
zookeeper:
image: wurstmeister/zookeeper
ports:
- “2181:2181”
kafka:
image: wurstmeister/kafka
ports:
- “9092:9092”
environment:
- KAFKA_ADVERTISED_HOST_NAME=localhost
- KAFKA_ADVERTISED_PORT=9092
- KAFKA_ZOOKEEPER_CONNECT=zookeeper:2181
- KAFKA_CREATE_TOPICS=“test:1:1”
depends_on:
- zookeeper
volumes:
- /var/run/docker.sock:/var/run/docker.sock
I have pushed data to topic and it’s working. I am getting the output. But for telegraf config i am getting - kafka: client has run out of available brokers to talk to (Is your cluster reachable?)
[[inputs.kafka_consumer]]
brokers = [“localhost:9092”]
topics = [“test”]
version = “2.7.0”
Then i referred here - Possibility to access kafka contaner from other container · Issue #575 · wurstmeister/kafka-docker · GitHub
version: ‘2’
services:
zookeeper:
image: wurstmeister/zookeeper:3.4.6
ports:
- “2181:2181”
kafka:
image: wurstmeister/kafka:2.11-2.0.0
depends_on:
- zookeeper
ports:
- “9092:9092”
expose:
- “9093”
environment:
KAFKA_ADVERTISED_LISTENERS: INSIDE://kafka:9093,OUTSIDE://localhost:9092
KAFKA_LISTENER_SECURITY_PROTOCOL_MAP: INSIDE:PLAINTEXT,OUTSIDE:PLAINTEXT
KAFKA_LISTENERS: INSIDE://0.0.0.0:9093,OUTSIDE://0.0.0.0:9092
KAFKA_ZOOKEEPER_CONNECT: zookeeper:2181
KAFKA_INTER_BROKER_LISTENER_NAME: INSIDE
KAFKA_CREATE_TOPICS: ‘Sometopic:1:1’
KAFKA_AUTO_CREATE_TOPICS_ENABLE: ‘true’
volumes:
Again producer and consumer is working fine but with telegraf same error is showing. For broker i tried all configs - kafka:9093,localhost:9092,kafka:9092,localhost:9093 still every time error is showing. What to do now?
