[inputs.kafka_consumer] Error in plugin: EOF
When I collect kafka data with telegraf,I got EOF error.
This is my telegraf conf.
[[inputs.kafka_consumer]]
Kafka brokers.
brokers = [“localhost:9092”]
Topics to consume.
topics = [“test”]
When set this tag will be added to all metrics with the topic as the value.
topic_tag = “test”
The Error alert mes is :
How can i solve this error ?
Hi @Watson
  • Set debug = true in the [agent] section
  • Send your data to stdout
Has data_format = been specified?
Thanks for your reply,i set dug = true then the detail are sarama can’t fetch metadata.I swith to [[inputs.kafka_consumer_legacy]] ,the alert msg is
[telegraf] Error running agent: starting input inputs.kafka_consumer_legacy: kafka: client has run out of available brokers to talk to: 6 errors occurred:t
Thanks for you help,the sarema 1.32 version can’t fetch metadata from kafka brokers,so i use telegraf 1.14 version solve this error.
@Watson Great news! Good luck with your project.
