Telegraf 1.17.0 (git: HEAD 3f7a54c)
Linux sophie 5.4.0-58-generic #64-Ubuntu SMP (Ubuntu 20.04)
smartmontools release 7.1 dated 2019-12-30 at 15:00:11 UTC
- Trying to specify the individual drives within the Areca RAID array from within the [input.smart] section of telegraf.conf fails
- Any one of the following lines works:
devices = [ "/dev/sg3 -d areca,2/2" ] # A single drive from the Areca array, indicated via 'areca,2/2'
devices = [ "/dev/sg3 -d areca,7/2" ] # A different drive from the Areca array - 'areca 7/2'
devices = [ "/dev/sg3 -d areca,1/2", "/dev/sdd" ] # Multiple drives, so long as only one is from the Areca array
devices = [ "/dev/sdd", "/dev/sdd"] # Duplicating the same non-Areca drive seems to work without error
- But the following doesn’t work:
devices = [ "/dev/sg3 -d areca,2/2", "/dev/sg3 -d areca,3/2" ] # Two drives from within the Areca array
Expected behaviour:
Smartctl can retrieve data from individual drives within a hardware array provided the ‘–device=’ parameter is correct.
For Areca arrays, the following is correct syntax:
smartctl --info --health --attributes --tolerance=verypermissive -n standby --format=brief --device=areca,1/2 /dev/sg3
This returns comprehensive data about the specific drive within the array:
root@sophie:/etc/telegraf# smartctl --info --health --attributes --tolerance=verypermissive -n standby --format=brief --device=areca,1/2 /dev/sg3
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-58-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: HGST HDN721010ALE604
Serial Number: 1SJS3J5Z
LU WWN Device Id: 5 000cca 26be6b0c3
Firmware Version: 83XN
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Jan 13 01:13:50 2021 PST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Power mode is: ACTIVE or IDLE
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance --S--- 135 135 054 - 92
3 Spin_Up_Time POS--- 175 175 024 - 406 (Average 344)
4 Start_Stop_Count -O--C- 100 100 000 - 99
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0
7 Seek_Error_Rate -O-R-- 100 100 067 - 0
8 Seek_Time_Performance --S--- 128 128 020 - 18
9 Power_On_Hours -O--C- 098 098 000 - 16232
10 Spin_Retry_Count -O--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 99
22 Unknown_Attribute PO---K 100 100 025 - 100
192 Power-Off_Retract_Count -O--CK 100 100 000 - 823
193 Load_Cycle_Count -O--C- 100 100 000 - 823
194 Temperature_Celsius -O---- 166 166 000 - 36 (Min/Max 17/59)
196 Reallocated_Event_Count -O--CK 100 100 000 - 0
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 0
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0
When a different value is used, Smartctl correctly retrieves the data for the different disk within the array:
root@sophie:/etc/telegraf# smartctl --info --health --attributes --tolerance=verypermissive -n standby --format=brief --device=areca,7/2 /dev/sg3
Serial Number: 1SJTUGKZ
LU WWN Device Id: 5 000cca 26be77786
Local Time is: Wed Jan 13 01:14:54 2021 PST
2 Throughput_Performance --S--- 134 134 054 - 96
3 Spin_Up_Time POS--- 178 178 024 - 316 (Average 424)
4 Start_Stop_Count -O--C- 100 100 000 - 109
9 Power_On_Hours -O--C- 098 098 000 - 20286
12 Power_Cycle_Count -O--CK 100 100 000 - 109
192 Power-Off_Retract_Count -O--CK 100 100 000 - 1020
193 Load_Cycle_Count -O--C- 100 100 000 - 1020
194 Temperature_Celsius -O---- 166 166 000 - 36 (Min/Max 16/62)
The [input.smart] plugin allows for specifying device and device type:
# ## Optionally specify devices and device type, if unset
# ## a scan (smartctl --scan and smartctl --scan -d nvme) for S.M.A.R.T. devices will be done
# ## and all found will be included except for the excluded in excludes.
# # devices = [ "/dev/ada0 -d atacam", "/dev/nvme0"]
devices = [ "/dev/sg3 -d areca,12/2" ]
The above works correctly:
root@sophie:/etc/telegraf# nano telegraf.conf
root@sophie:/etc/telegraf# telegraf --test| grep smart
2021-01-13T09:17:43Z I! Starting Telegraf 1.17.0
2021-01-13T09:17:43Z I! Using config file: /etc/telegraf/telegraf.conf
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=POSR--,host=sophie,id=1,model=ST10000NM0086-2AA101,name=Raw_Read_Error_Rate,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=344184i,threshold=44i,value=100i,worst=64i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO----,host=sophie,id=3,model=ST10000NM0086-2AA101,name=Spin_Up_Time,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=93i,worst=92i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=4,model=ST10000NM0086-2AA101,name=Start_Stop_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=51i,threshold=20i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO--CK,host=sophie,id=5,model=ST10000NM0086-2AA101,name=Reallocated_Sector_Ct,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=48i,threshold=10i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=POSR--,host=sophie,id=7,model=ST10000NM0086-2AA101,name=Seek_Error_Rate,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=427333388i,threshold=45i,value=86i,worst=60i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=9,model=ST10000NM0086-2AA101,name=Power_On_Hours,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=13568i,threshold=0i,value=85i,worst=85i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO--C-,host=sophie,id=10,model=ST10000NM0086-2AA101,name=Spin_Retry_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=97i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=12,model=ST10000NM0086-2AA101,name=Power_Cycle_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=53i,threshold=20i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=184,model=ST10000NM0086-2AA101,name=End-to-End_Error,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=99i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=187,model=ST10000NM0086-2AA101,name=Reported_Uncorrect,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=188,model=ST10000NM0086-2AA101,name=Command_Timeout,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O-RCK,host=sophie,id=189,model=ST10000NM0086-2AA101,name=High_Fly_Writes,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=68i,threshold=0i,value=32i,worst=32i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=Past,flags=-O---K,host=sophie,id=190,model=ST10000NM0086-2AA101,name=Airflow_Temperature_Cel,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=35i,threshold=40i,value=65i,worst=39i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=191,model=ST10000NM0086-2AA101,name=G-Sense_Error_Rate,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=11417i,threshold=0i,value=95i,worst=95i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=192,model=ST10000NM0086-2AA101,name=Power-Off_Retract_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=555i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=193,model=ST10000NM0086-2AA101,name=Load_Cycle_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=605i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O---K,host=sophie,id=194,model=ST10000NM0086-2AA101,name=Temperature_Celsius,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=35i,threshold=0i,value=35i,worst=61i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O-RC-,host=sophie,id=195,model=ST10000NM0086-2AA101,name=Hardware_ECC_Recovered,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=344184i,threshold=0i,value=100i,worst=64i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--C-,host=sophie,id=197,model=ST10000NM0086-2AA101,name=Current_Pending_Sector,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=----C-,host=sophie,id=198,model=ST10000NM0086-2AA101,name=Offline_Uncorrectable,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-OSRCK,host=sophie,id=199,model=ST10000NM0086-2AA101,name=UDMA_CRC_Error_Count,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=0i,value=200i,worst=200i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO---K,host=sophie,id=200,model=ST10000NM0086-2AA101,name=Multi_Zone_Error_Rate,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=0i,threshold=1i,value=100i,worst=100i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=------,host=sophie,id=240,model=ST10000NM0086-2AA101,name=Head_Flying_Hours,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=48344677i,threshold=0i,value=100i,worst=253i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=------,host=sophie,id=241,model=ST10000NM0086-2AA101,name=Total_LBAs_Written,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=140759859579i,threshold=0i,value=100i,worst=253i 1610529464000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=------,host=sophie,id=242,model=ST10000NM0086-2AA101,name=Total_LBAs_Read,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,raw_value=399844847220i,threshold=0i,value=100i,worst=253i 1610529464000000000
> smart_device,capacity=10000831348736,device=sg3,enabled=Enabled,host=sophie,model=ST10000NM0086-2AA101,serial_no=ZA29PM9W,wwn=5000c500b375b078 exit_status=32i,health_ok=true,read_error_rate=344184i,seek_error_rate=427333388i,temp_c=35i,udma_crc_errors=0i 1610529464000000000
As do any of the examples previously documented above.
However, the following doesn’t work:
devices = [ "/dev/sg3 -d areca,1/2", "/dev/sg3 -d areca,7/2" ]
Actual behavior:
The following is the output from specifying more than one drive within the areca array:
2021-01-13T09:20:36Z I! Starting Telegraf 1.17.0
2021-01-13T09:20:36Z I! Using config file: /etc/telegraf/telegraf.conf
> smart_device,device=sg3,host=sophie exit_status=2i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO-R--,host=sophie,id=1,model=HGST\ HDN721010ALE604,name=Raw_Read_Error_Rate,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=16i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=--S---,host=sophie,id=2,model=HGST\ HDN721010ALE604,name=Throughput_Performance,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=92i,threshold=54i,value=135i,worst=135i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=POS---,host=sophie,id=3,model=HGST\ HDN721010ALE604,name=Spin_Up_Time,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=406i,threshold=24i,value=175i,worst=175i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--C-,host=sophie,id=4,model=HGST\ HDN721010ALE604,name=Start_Stop_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=99i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO--CK,host=sophie,id=5,model=HGST\ HDN721010ALE604,name=Reallocated_Sector_Ct,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=5i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O-R--,host=sophie,id=7,model=HGST\ HDN721010ALE604,name=Seek_Error_Rate,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=67i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=--S---,host=sophie,id=8,model=HGST\ HDN721010ALE604,name=Seek_Time_Performance,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=18i,threshold=20i,value=128i,worst=128i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--C-,host=sophie,id=9,model=HGST\ HDN721010ALE604,name=Power_On_Hours,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=16232i,threshold=0i,value=98i,worst=98i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--C-,host=sophie,id=10,model=HGST\ HDN721010ALE604,name=Spin_Retry_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=60i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=12,model=HGST\ HDN721010ALE604,name=Power_Cycle_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=99i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=PO---K,host=sophie,id=22,model=HGST\ HDN721010ALE604,name=Unknown_Attribute,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=100i,threshold=25i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=192,model=HGST\ HDN721010ALE604,name=Power-Off_Retract_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=823i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--C-,host=sophie,id=193,model=HGST\ HDN721010ALE604,name=Load_Cycle_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=823i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O----,host=sophie,id=194,model=HGST\ HDN721010ALE604,name=Temperature_Celsius,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=36i,threshold=0i,value=166i,worst=166i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O--CK,host=sophie,id=196,model=HGST\ HDN721010ALE604,name=Reallocated_Event_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O---K,host=sophie,id=197,model=HGST\ HDN721010ALE604,name=Current_Pending_Sector,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=---R--,host=sophie,id=198,model=HGST\ HDN721010ALE604,name=Offline_Uncorrectable,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=0i,value=100i,worst=100i 1610529637000000000
> smart_attribute,capacity=10000831348736,device=sg3,enabled=Enabled,fail=-,flags=-O-R--,host=sophie,id=199,model=HGST\ HDN721010ALE604,name=UDMA_CRC_Error_Count,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,raw_value=0i,threshold=0i,value=200i,worst=200i 1610529637000000000
> smart_device,capacity=10000831348736,device=sg3,enabled=Enabled,host=sophie,model=HGST\ HDN721010ALE604,serial_no=1SJS3J5Z,wwn=5000cca26be6b0c3 exit_status=0i,health_ok=true,read_error_rate=0i,seek_error_rate=0i,temp_c=36i,udma_crc_errors=0i 1610529637000000000
Only the first drive gets reported on. Any subsequent drives within that same array don’t, with only the 'exit_status=2i" message returned.
Strangely, the following works:
devices = [ "/dev/sdf", "/dev/sdf", "/dev/sdf", "/dev/sdf" ]
so it doesn’t appear to be a problem with handling duplicate drives.
Additional info:
Issue #4720 was logged by @sachaz Sept 19,2018 which was identical, except he was using an HP smart array instead of an Areca, but the principle is the same - you must use the ‘-d’ parameter to specify individual drives within the array.
