InfluxQL to new task FLUX with resample and group
I 6 hour try convert influxQL to FLUX query. Any can do it ?
CREATE CONTINUOUS QUERY trade_to_candles_60 ON mydb
RESAMPLE EVERY 10s FOR 10m
BEGIN SELECT first(price) AS open, last(price) AS close, max(price) AS high, min(price) AS low, sum(amount) AS volume INTO
candles_1m FROM trades WHERE
GROUP BY time(1m), pair, exchange END
@shclonk You’re going to need to create a Flux task. If you create the task through the InfluxDB UI, leave out the options statement. The UI autogenerates that using the specified task settings. If you’re add the task through the API or the CLI, leave the options statement in.
import "experimental"
options task = {
  every: 10s
price = from(bucket: "mydb")
  |> from(start: -10m)
  |> filter(fn: (r) => r._measurement == "trades" and r._field == "price")
amount = price = from(bucket: "mydb")
  |> from(start: -10m)
  |> filter(fn: (r) => r._measurement == "trades" and r._field == "amount")
minMaxLast = (tables=<-, column) => tables |> reduce(
  identity: {last: 0.0, max: 0.0, min: 0.0},
  fn: (r, accumulator) => {(
    last: r._value,
    min: if r._value < accumulator.min then r._value else accumlator.min,
    max: if r._value > accumlator.max then r._value else accumlator.max,
pivotedPrice = price |> aggregateWindow(every: 1m, fn: minMaxLast)
pivotedAmount = amount
  |> aggregateWindow(every: 1m, fn: sum)
join(tables: [price: pivotedPrice, amount: pivotedAmount], on: "_time")
  |> experimental.set(o: {_min_price: "low", _max_price: "high", _last_price: "close", _amount_amount: "value"})
  |> experimental.to(bucket: "candles_1m")
thx wow so hardy after sql )
The Flux team has plans to make the syntax for these mutli-aggregate queries a little simpler. This is only one approach. Here’s another way you could do it:
options task = {
  every: 10s
data = from(bucket: "mydb")
  |> from(start: -10m)
  |> filter(fn: (r) => r._measurement == "trades")
close = data
  |> filter(fn: (r) => r._field == "price")
  |> aggregateWindow(every: 1m, fn: last)
  |> set(key: "_field", value: "close")
high = data
  |> aggregateWindow(every: 1m, fn: max)
  |> set(key: "_field", value: "high")
low = data
  |> aggregateWindow(every: 1m, fn: min)
  |> set(key: "_field", value: "low")
amount = data
  |> filter(fn: (r) => r._field == "amount")
  |> set(key: "_field", value: "amount")
union(tables: [close, high, low, amount])
does this syntax already work? or when will it be available?
It’s not available yet, but you can look through the proposal here: Flux Usability Study and Language Proposal · GitHub
I don’t know the timeframe for when this will be implemented.
Hello. A year has passed. Has the new syntax not appeared?
Hi. Well, it’s been two years. In that time we have become a major exchange, and you have released version 3 where they say completely redesigned SQL native syntax.
So after 2 years the question, how will my request look like on v3?
The answer is : now they give up on Flux and they are going back to InfluxQL/SQL for InfluxDB 3.0 as u may have read.
