[InfluxQL to Flux] show the calculated column in graph
I am trying to migrate influx from 1.8 to 2.2, but I got a problem for one InfluxQL.
The original influxQL is
SELECT mean("markPrice") AS "markPrice", mean("realPrice") AS "expectedPrice",  mean("markPrice")-mean("realPrice") AS "timeValue"  FROM "mydb"."autogen"."MoveData" WHERE time > now() - 24h AND time < now() AND "type"='DAYMove' GROUP BY time(:interval:) FILL(null)
It’s a simple query and the graph will show 3 lines, one is calculated with mean(“markPrice”)-mean(“realPrice”)
Then I tried to rewrite with flux, but can’t figure out how to draw the calculated line in graph.
I’m new for FLUX, and I have read the document, but still not find out the answer.
use Pivot and map() function | Flux 0.x Documentation function to calculate it.
first add this line after line no 6
pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
then
|> map(fn: (r) =>
            r with
            _value: (r.markPrice - r.realPrice)
It will calculate mean(markPrice) - mean(realPrice)
thanks for your reply. I tried this before I post this thread. My problem is how display all the 3 lines in the graph, after run the updated script, only one line is plotted.
from(bucket: "mydb/autogen")
  |> filter(fn: (r) => r["_measurement"] == "MoveData")
  |> filter(fn: (r) => r["_field"] == "markPrice" or r["_field"] == "realPrice")
  |> filter(fn: (r) => r["type"] == "DAYMove")
  |> map(fn: (r) =>
              r with
  |> yield(name: "mean")
I want to show something like is
Write two queries
query1 = from(bucket: "mydb/autogen")
  |> map(fn: (r) =>
              r with
  |> yield(name: "mean")
query2 = from(bucket: "mydb/autogen")
  |> yield(name: "last")
It will plot all three graphs.
