I am trying to use v1 compatibility mode against an influx cloud instance and I get a 501 for /query. I have followed all instructions listed here InfluxDB 1.x compatibility API | InfluxDB Cloud Documentation to query with a token. I know that my token is correct as I can use it against other endpoints. Additionally if I change my token I get a 401. This implies I have a correct token getting passed the auth, but then I get a 501 from query endpoint.
curl -v --get "https://us-east-1-1.aws.cloud2.influxdata.com/query" \
--header "Authorization: Token <token>" \
--header 'Content-type: application/json' \
--data-urlencode "db=metrics" \
--data-urlencode "q=SELECT * FROM cpu_usage"
results in
< HTTP/2 501
< date: Tue, 04 Apr 2023 23:49:56 GMT
< content-type: application/json; charset=utf-8
< content-length: 54
< request-id: bd76494b5aae2bf4757fdc20c522aefb
< trace-id: 59d15201432bbc1d
< trace-sampled: false
< vary: Accept-Encoding
< x-platform-error-code: not implemented
< x-request-id: bd76494b5aae2bf4757fdc20c522aefb
< strict-transport-security: max-age=15724800; includeSubDomains
< x-influxdb-request-id: bd76494b5aae2bf4757fdc20c522aefb
< x-influxdb-build: Cloud
I have confirmed the metrics dbrp is setup
influx v1 dbrp list
ID Database Bucket ID Retention Policy Default Organization ID
0afe7de4228aa000 metrics <removed> default-rp true <removed>
also of note, if I use the cli with v1 shell, I get a 501 with every query as well
