InfluxDB Error: retention policy not found: autogen
grafana 9.1 with influxdb 2.4
How to fix this problem ?
autogen is the name of the default retention policy (if enabled).
Whatâs the default RP you set on InfluxDB? (run SHOW RETENTION POLICIES)
The solution is pretty simple⊠just specify it SELECT * FROM _RetPoliciy_.cpu
I got same error, and will share what I have tested.
At Influxdb I run:
influx v1 dbrp list
Then see all buckets using the autogen âRetention Policyâ.
But, if I do same check using:
influx bucket list
The field / collumn âRetention Policyâ does not exists.
I have tried switch on Query Language at Data Sources:
From InfluxQL to Flux
Then no happen the error:
runRequest.ts:151 runRequest.catchError {"message":"InfluxDB Error: retention policy not found: autogen"}
But instead, got a new error:
fetch.js:32 POST https://grafana.domain.com/api/ds/query 400
In the Explore Menu I can query Influxdb using use option Sample Query from Flux, but server start flood with this error from /api/ds/query.
Everything seems ok at InfluxDB side, the default dashboard (from InfluxDB no Grafana) use the data from buckets, and query works too.
Using Postman on https://influxdb.domain.com/api/v2/dbrps?org=ORGNAME returns:
"content": [
"id": "xxxxxxxxxxxxxxxx",
"database": "database",
"retention_policy": "autogen",
"default": true,
"virtual": true,
"orgID": "xxxxxxxxxxxxxxxx",
"bucketID": "xxxxxxxxxxxxxxxx"
PS.: On my setup I did subdomains for influxdb and grafana. CORS is using the â*â.
Hi there !
I found a solution to the problem that I also encountered. The issue was in my Datasource definition on Grafana in the Query Language option.
I had selected in âQuery Languageâ the InfluxQL option. I finally figured that all I did on InfluxDB was with Flux query language, so it would make more sense using Flux on Grafana too.
Changed it and it now works perfectly !!
It also makes more sense because it includes the API Token in the Datasource form directly.
I have found the solution at grafana forum on this link:
https://community.grafana.com/t/database-not-found-error-grafana-influxdb-source/61064
My guess, grafana fails on check the flags Retention Policy and Default⊠Why?
After follow the setup from medium post (link at grafana forums) I have checked the changes with:
influx v1 dbrp list
Then Retention Policy need be autogen and Default need be false or donât work. (Before was autogen and true)
Now Iâm searching why the error using Flux option at my setup happens.
The old InfluxQL now itâs working, but I wish fix the second option too.
I would like to chime in here because i have been getting this error âInfluxDB Error: retention policy not found: autogenâ as well. In my case. I have an ton of old dashboards on a older Grafana 8.4.2 and InfluxDB 1.8.10 setup.
I had decided to work toward updating and started using the Grafana 9.1.5 and InfluxDB 2.4.0 in a Docker container which in itself so far is a learning curve but isnât to bad. Although I do wish I could use the Flux language for the plugin, the Fact is I have so many dashboards built on the older InfluxQL language that I donât want to rebuild.
Any how, after configuring telegraf to point to the new influxDB v2 output plugin and configuring grafana for the Influx Data source I came across this error in about the autgen policy not found. I have spent the week trying to work through or work around it and figure it out, but I finally I saw @Wisdom 's post that the retention policy for autogen needs to NOT be âdefaultâ which finally allowed my dashboard to load!!
In fumbling around trying to set the autogen policy to false i couldnât seem to update this existing read only policy, so in the end what worked for me was creating a new policy (apparently it is default) but isnât read only âŠthis changes the read only autogen policy to default = false, but attempts to remove this duplicate new non-readonly autogen policy break my dashboard again so apparently it must be there.
Before:
root@b38e3b8e242d:/# influx v1 dbrp ls
ID Database Bucket ID Retention Policy Default Organization ID
VIRTUAL DBRP MAPPINGS (READ-ONLY)
9fe148f3e30ddec3 _monitoring 9fe148f3e30ddec3 autogen true 2d0717a9a02a4d9e
9199596572587bde _tasks 9199596572587bde autogen true 2d0717a9a02a4d9e
80731b030126e621 telegraf 80731b030126e621 autogen true 2d0717a9a02a4d9e
Create retention policy with this command
root@b38e3b8e242d:/# influx v1 dbrp create \
> --db telegraf \
> --rp autogen \
> --bucket-id 80731b030126e621
09fc9637efc75000 telegraf 80731b030126e621 autogen true 2d0717a9a02a4d9
After:
09fc9637efc75000 telegraf 80731b030126e621 autogen true 2d0717a9a02a4d9e
80731b030126e621 telegraf 80731b030126e621 autogen false 2d0717a9a02a4d9e
Iâm still not sure which one itâs using but considering it broke when i tried to remove the new autogen = true policy i believe it is that one
Awesome, thanks! That also solved it for me. Was also running a fresh 2.4 instance.
Before, which didnât work and just caused the missing autogen error everywhere:
user@pc:~$ influx v1 dbrp list
46896f35921cd549 _monitoring 46896f35921cd549 autogen true 213d4e1072307065
62ad043c97265540 _tasks 62ad043c97265540 autogen true 213d4e1072307065
a7e2192365f4385d homeassistant a7e2192365f4385d autogen true 213d4e1072307065
97a76f92708d4527 quickstart 97a76f92708d4527 autogen true 213d4e1072307065
Added the explicit mapping:
user@pc:~$ influx v1 dbrp create --db homeassistant --rp autogen --bucket-id a7e2192365f4385d
0a3a6b8c5a474000 homeassistant a7e2192365f4385d autogen true 213d4e1072307065
And got:
a7e2192365f4385d homeassistant a7e2192365f4385d autogen false 213d4e1072307065
And now everything was working properly. Grafana, old Python client, everything.
