It throws the following error:
ERR: error parsing query: found influx, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
How do I fix the error? Also I’d like to know if there’s a way by which I can export the database in one go, instead of exporting one measurement/table one at a time? Many thanks in advance.
