Hi,@ Jay_Clifford
If I consider storing massive IOT data in influxdb through mqtt telegraf plug-in, can I compress the data, Some compression algorithms can be configured
InfluxDB already compacts its data, the process is called compaction.
There are some options/settings related to compaction but not about its algorithm.
