I have a query, that shows some data from aggregated windows (24h). One value is a maximum Energy value, that should be shown from the beginning of the day, the other value Temp (mean, max, min) should be shown in the diagram at 12:00. When using the offset function, the result of the mean value is aligned correctly, but the value is of course wrong. Is there a way to shift the mean value without the offset to the middle of the window?
Here’s the query
from(bucket: "myBucket")
|> filter(fn: (r) => r["_field"] == "Energy")
|> aggregateWindow(every: 24h, fn: max, createEmpty: false)
|> yield(name: "max Energie")
|> filter(fn: (r) => r["_field"] == "Temp")
|> yield(name: "mean")
|> yield(name: "max")
|> yield(name: "min")
Thank you for your help!
