Bedas
1
I see no messages appearing in journal once InfluxDB gets fully started:
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: Merging with configuration at: /etc/influxdb/influxdb.conf
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: ts=2021-10-26T20:29:35.805875Z lvl=info msg="InfluxDB starting" log_id=0XR_YbkG000 version=1.8.10 branch=1.8 commit=688e697c51fd
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: ts=2021-10-26T20:29:35.805935Z lvl=info msg="Go runtime" log_id=0XR_YbkG000 version=go1.13.8 maxprocs=20
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: InfluxDB API unavailable after 1 attempts...
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: ts=2021-10-26T20:29:35.908217Z lvl=info msg="Using data dir" log_id=0XR_YbkG000 service=store path=/db/influxdb/data
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: ts=2021-10-26T20:29:35.908300Z lvl=info msg="Compaction settings" log_id=0XR_YbkG000 service=store max_concurrent_compactions=10 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
Oct 26 20:29:35 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: ts=2021-10-26T20:29:35.908326Z lvl=info msg="Open store (start)" log_id=0XR_YbkG000 service=store trace_id=0XR_Yc90000 op_name=tsdb_open op_event=start
.......a lot of output here.............
Oct 26 20:30:07 aln2opssrvts201-oam2.wnsnet.attws.com influxd-systemd-start.sh[1187]: [httpd] 127.0.0.1 - - [26/Oct/2021:20:30:07 +0000] "GET /health HTTP/1.1" 200 107 "-" "curl/7.29.0" 824b7cd8-369b-11ec-8001-5254007dcde3 792
Oct 26 20:30:07 aln2opssrvts201-oam2.wnsnet.attws.com systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
and that’s it. No more messages such is http POST or GET or compactions and other stuff.
influxdb.conf is set per default. Even tho the logging section is commented out, that means it’s set as per default states.
[logging]
# format = "auto"
# level = "info"
# suppress-logo = false
[http]
log-enabled = true
[data]
trace-logging-enabled = true
query-log-enabled = true
Hello @Bedas
Can you please share your whole config?
Thank you
Bedas
3
@Anaisdg thanks for response.
AMOF I found out that all the output is being shown in system log if I run journalctl -xe
But nothing for journalctl -f -u influxdb
or I tried other variation such journalctl -f -o cat _SYSTEMD_UNIT=influxdb.service
Here you go…
[foo@bar influxdb]$ cat influxdb.conf | egrep "\[\w+\]|="
reporting-disabled = true
# bind-address = "127.0.0.1:8088"
### [meta]
[meta]
dir = "/db/influxdb/meta"
# retention-autocreate = true
# logging-enabled = true
### [data]
[data]
dir = "/db/influxdb/data"
wal-dir = "/db/influxdb/wal"
# wal-fsync-delay = "0s"
# index-version = "inmem"
# validate-keys = false
# Valid size suffixes are k, m, or g (case insensitive, 1024 = 1k).
# cache-max-memory-size = "1g"
# cache-snapshot-memory-size = "25m"
# cache-snapshot-write-cold-duration = "10m"
# compact-full-write-cold-duration = "4h"
# max-concurrent-compactions = 0
# compact-throughput = "48m"
# compact-throughput-burst = "48m"
# tsm-use-madv-willneed = false
max-series-per-database = 4000000
max-values-per-tag = 110000
# max-index-log-file-size = "1m"
series-id-set-cache-size = 100
### [coordinator]
[coordinator]
write-timeout = "9s"
max-concurrent-queries = 30
query-timeout = "60s"
log-queries-after = "30s"
# max-select-point = 0
# max-select-series = 0
# max-select-buckets = 0
### [retention]
[retention]
# enabled = true
# check-interval = "30m"
# enabled = true
# check-interval = "10m"
# advance-period = "30m"
[monitor]
# store-enabled = true
# store-database = "_internal"
store-interval = "60s"
### [http]
[http]
# enabled = true
# flux-enabled = false
# flux-log-enabled = false
# bind-address = ":8086"
# auth-enabled = false
# realm = "InfluxDB"
log-enabled = true
# suppress-write-log = false
# access-log-path = ""
# access-log-status-filters = []
# write-tracing = false
# pprof-enabled = true
# pprof-auth-enabled = false
# debug-pprof-enabled = false
# ping-auth-enabled = false
# https-enabled = false
# https-certificate = "/etc/ssl/influxdb.pem"
# https-private-key = ""
# shared-secret = ""
# max-row-limit = 0
# max-connection-limit = 0
# unix-socket-enabled = false
# bind-socket = "/var/run/influxdb.sock"
# max-body-size = 25000000
# max-concurrent-write-limit = 0
# max-enqueued-write-limit = 0
# enqueued-write-timeout = 0
# X-Header-1 = "Header Value 1"
# X-Header-2 = "Header Value 2"
### [logging]
[logging]
# format = "auto"
# level = "info"
### [subscriber]
[subscriber]
# enabled = true
# http-timeout = "30s"
# insecure-skip-verify = false
# ca-certs = ""
# write-concurrency = 40
# write-buffer-size = 1000
### [[graphite]]
[[graphite]]
# enabled = false
# database = "graphite"
# retention-policy = ""
# bind-address = ":2003"
# protocol = "tcp"
# consistency-level = "one"
# batch-size = 5000
# batch-pending = 10
# batch-timeout = "1s"
# udp-read-buffer = 0
# separator = "."
# tags = ["region=us-east", "zone=1c"]
# templates = [
### [collectd]
[[collectd]]
# enabled = false
# bind-address = ":25826"
# database = "collectd"
# typesdb = "/usr/local/share/collectd"
# security-level = "none"
# auth-file = "/etc/collectd/auth_file"
# batch-size = 5000
# batch-timeout = "10s"
# read-buffer = 0
# parse-multivalue-plugin = "split"
### [opentsdb]
[[opentsdb]]
# enabled = false
# bind-address = ":4242"
# database = "opentsdb"
# tls-enabled = false
# certificate= "/etc/ssl/influxdb.pem"
# log-point-errors = true
# batch-size = 1000
# batch-pending = 5
### [[udp]]
[[udp]]
# enabled = false
# bind-address = ":8089"
# database = "udp"
# precision = ""
# batch-size = 5000
# read-buffer = 0
### [continuous_queries]
# enabled = true
log-enabled = true
# query-stats-enabled = false
# run-interval = "1s"
### [tls]
[tls]
# ciphers = [
# min-version = "tls1.2"
# max-version = "tls1.3"
