Hello All,
am using 4 different queries to display in table and I need to filter these queries according to my requirements to display Cisco BGP/CDP required value/fields in table. The required queries are mentioned below . What/how could be the best options to do it.
from(bucket: “telegraf”)
|> filter(fn: (r) => r[“subscription”] == “RoutingBGPSubscription”)
|> filter(fn: (r) => r[“source”] == “XRV9K10”)
|> filter(fn: (r) => r[“_field”] == “remote_as_number”)
|> filter(fn: (r) => r[“_measurement”] == “Cisco-IOS-XR-ipv4-bgp-oper:bgp/instances/instance/instance-active/default-vrf/neighbors/neighbor”)
|> distinct()
|> group()
|> drop(columns: [“_start”,“_stop”,“host”,“path”,“subscription”,“_measurement”,“instance_name” ])
|> rename(columns: {neighbor_address: "BGP Remote Speaker IP ", _value: “Remote AS Number”})
|> yield(name: “distinct”)
|> filter(fn: (r) => r[“source”] ==“${Device}”)
|> filter(fn: (r) => r[“_field”] == “connection_local_address/ipv4_address”)
|> distinct()
|> group()
//|> yield(name: “distinct”)
|> drop(columns: [“_start”,“_stop”,“host”,“path”,“subscription”])
|> rename(columns: {source: “Cisco IOS XR Host Name”, neighbor_address: “BGP Remote Speaker IPs”, _value :“BGP Local Speaker IP” })
|> filter(fn: (r) => r[“_field”] == “router_id”)
|> rename(columns: { neighbor_address: “BGP Remote Speaker IPs”, _value :“Remote AS Number” })
|> distinct()
|> group()
|> filter(fn: (r) => r[“_field”] == “cdp_neighbor/device_id” or r[“_field”] == “cdp_neighbor/port_id”)
|> filter(fn: (r) => r[“_measurement”] == “Cisco-IOS-XR-cdp-oper:cdp/nodes/node/neighbors/summaries/summary”)
|> distinct()
|> group()
