I’m trying to view some data in the UI of influx. The problem I have is that sometimes you just want to shift the data range a bit. For that purpose I’m searching for some panning feature (or even better a possibility to add buttons “+ 1 day” and “- 1 day”).
Am I simply missing this feature (not finding some config option/keybinding) or is this simply currently not possible?
Hello @atticus-sullivan,
that’s a great idea.
I encourage you submit a feature request here:
You can select the data you want with the range function:
Or with the calendar feature in the UI called the Custom Time Range:
