Is there a possiblity to know and use the current index during an iteration in the map() functions?
For example I want to use it as a new column:
b = a |> array.map(fn: (x) => ({_value: x, index: ????}))
If someone has the solution, my ultimate goal is to expand one record with an array into several records on the primitive type. For example:
|_time | _value (string)|
|2021-01-01T00:00:00Z | [1, 2, 3, 4]|
|2021-01-01T00:00:10Z | [10, 20, 30, 40]|
into:
|_time | _value (int)|serie|
|2021-01-01T00:00:00Z |1|0|
|2021-01-01T00:00:00Z |2|1|
|2021-01-01T00:00:00Z |3|2|
|2021-01-01T00:00:00Z |4|3|
|2021-01-01T00:00:10Z |10|0|
|2021-01-01T00:00:10Z |20|1|
|2021-01-01T00:00:10Z |30|2|
|2021-01-01T00:00:10Z |40|3|
Thank you
