hello
in the following flux query, I want to return
_time, Longitude,Latitude,Flag
from(bucket: "PSK")
|> filter(fn: (r) => r._field == "Longitude" or r._field == "Latitude" or r._field == "Flag")
|> filter(fn: (r) => r["Mode"] == "FT8")
|> keep(columns: ["_time", "_value", "_field", "Flag"])
This does return those columns but in grafana it groups them by Flag. WOnder if the issue is dataframes in grafana
THanks
scott
June 10, 2024, 7:29pm
2
@yosiasz Is Flag a field or a tag. I can’t tell from your query.
The following would indicate that it’s a field:
But this indicates it’s a tag:
In the Flux data structure, fields are represented by two columns: _field (the field key) and _value (the field value). Tags are represented by a single column where the column name is the tag key and the column value is the tag value.
So if Flag is a tag, it’s 1) not affected by the pivot and 2) is, by default, part of the group key which explains why Grafana is using it to group data.
this is the line protocol
M1CVZ,Band=20m,Continent=EU,Country=Sweden,Flag=🇸🇪,Mode=FT8,topic=pskr/filter/v2/20m/FT8/M1CVZ/SM2GHI/IO91/KP25/223/284 RxCC="284",TxCC="223",Maidenhead="KP25ax",Call="SM2GHI",Signal=-13,Sequence="4.7309249901e+10",Frequency=14075941,Latitude=65.95833333333333,Longitude=24 1718040720000000000
M1CVZ,Band=20m,Continent=EU,Country=Norway,Flag=🇳🇴,Mode=FT8,topic=pskr/filter/v2/20m/FT8/M1CVZ/LA1PHA/IO91/JP76/223/266 RxCC="266",TxCC="223",Maidenhead="JP76bh75",Call="LA1PHA",Signal=-16,Sequence="4.7309188289e+10",Frequency=14075435,Latitude=66.3125,Longitude=14.141666666666667 1718040524000000000
Ok, in fact it does have a LOT of tags. until the field sets start at RxCC
Ok thanks
scott
June 10, 2024, 8:05pm
4
@yosiasz Ok, since Flag is a tag and it’s the only column in the group key left after the pivot, you can just ungroup your data:
from(bucket: "PSK")
|> filter(fn: (r) => r._field == "Longitude" or r._field == "Latitude")
|> group()
Thanks so much, that was it!
