i wrote this configfile
Global Agent Configuration
[agent]
interval = “1m”
Input Plugins
[[inputs.mqtt_consumer]]
name_prefix = “sensors_”
servers = [“localhost:1883”]
qos = 0
connection_timeout = “30s”
topics = [
“/m1/#”,
“/m2/#”,
“/m3/#”,
“/m4/#”,
“/id_machine/#”,
“/1/#”,
“/2/#”,
persistent_session = false
data_format = “value”
data_type = “float”
Output Plugins
[[outputs.influxdb]]
database = “testdb”
urls = [ “http://localhost:8086” ]
that writes all information in one single table “sensors_mqtt_consumer” i dont know how to modify it to be able to write every single topic in one table .
any help ?
While I don’t understand the need to necessarily split the data between different tables, it should be possible. I’ll give you a few ideas - without guarantee - to try out for yourself.
I would try a processors plugin.
- Option 1: It definitely works with a
processors.execd plugin. But you have to write it yourself in any programming or scripting language.
- Option 2: It should also work with a
processors.starlark plugin. The advantage would be that the starlark script code can be located directly in the config file.
- Option 3: It could also work with the
processors.override or processors.rename plugins. Approximately as outlined below.
[[processors.rename]]
fieldpass = ["topics/m1*"] # how your topic field is named
[[processors.rename.replace]]
measurement = "sensors_mqtt_consumer"
dest = "topics_m1" # your new table/measurement name
fieldpass = ["topics/id_machine*"] # how your topic field is named
dest = "topics_id_machine" # your new table/measurement name
fieldpass = ["topics/1*"] # how your topic field is named
dest = "topics_1" # your new table/measurement name
# and so on...
Here is a suggestion how the whole thing could work with a processors.starlark plugin. No guarantee if it works exactly like this, I did not test it, but only wrote it down theoretically. If it doesn’t work, tinker a bit more yourself.
[[processors.starlark]]
# Source of the Starlark script.
source = '''
# adjust the field names in the first row, they have to match exactly!
renames = {
"/m1/#" : "meas_m1",
"/m2/#" : "meas_m2",
"/m3/#" : "meas_m3",
"/m4/#" : "meas_m4",
"/id_machine/#": "meas_id",
"/1/#" : "meas_1",
"/2/#" : "meas_2",
def apply(metric):
# Initialize a list of new metrics
metrics = []
# iterate through all fields of the current metric
for k, v in metric.fields.items():
if k in renames:
new_metric = Metric(renames[k]) # Create a new metric
new_metric.fields[renames[k]] = v
metrics.append(new_metric) # Add metric to the list of metrics
return metrics # Return the new list of metrics
