I want to add a line chart displaying three lines: total_data (total_data_bytes), rx (rx_data_bytes), and tx (tx_data_bytes). I use this query below at first:
from(bucket: "wifi")
|> filter(fn: (r) => r["_measurement"] == "Client" and r["client_user_name"] =~ /^${userName:regex}$/)
|> filter(fn: (r) => r._field == "total_data_bytes" or r._field == "rx_data_bytes" or r._field == "tx_data_bytes")
|> aggregateWindow(every: 1m, fn: mean, createEmpty: false)
|> drop(columns:["_measurement"])
However, I noticed an issue with this chart where some lines appear identical.
This might be because users can connect to multiple Wi-Fi access points (APs). To address this, probably i have to consider summing the values for identical parameters. For example, if there are four rx_data_bytes lines, you could sum them into a single “Total Rx Data” line.
How to do that? Can someone tell me to build the query? Thank you so much!
