When doing a query like this:
from(bucket: "mydata")
|> range(start: 2023-06-15T18:00:00.000Z, stop: 2023-07-01T21:00:00.000Z)
|> filter(fn: (r) => r["entity_id"] == "external_temperature")
|> filter(fn: (r) => r["_field"] == "value")
I get a chart with those unwanted lines:
My bucket had a hole in the data that I augmented later from another source.
But, if I “sort” the data by leaving out the _start and _stop columns and also sort by _time like so:
|> drop(columns: ["_start", "_stop"]) // <-- THIS FIXES THE ISSUE
|> sort(columns: ["_time"]) // <-- THIS FIXES THE ISSUE
then the wrong data disappears:
Note that just dropping _start and _stop is not enough: I must also sort by _time.
So my question is: how can I delete/remove the wrong data and avoid dropping the _start and _stop columns in the queries? I’m unable to identify the wrong data, apart from seeing in the raw results that near the end the records with _time restart from the beginning:
This is a sample of a single value, but I have other values with the same issue (and a different overlapping time) so I’m looking a way to “consolidate” the data just like the sorting does.
EDIT: Curious to note that on the results the first column table changes from 0 to 1 and I would like to basically trash those values with 1… but how can I “select” them?
