Hi
I have an ActiveMQ broker and data is coming to the queue inside this broker.
I am trying to read the data from the same broker but I am not able to read the data.
Below I have given my telegraf configuration. I have provided the topic name.
I tried creating a topic and sending custom data and that data I am able to read properly.
[[inputs.mqtt_consumer]]
servers = ["mqtt+ssl://b-1-1.mq.ap-south-1.amazonaws.com:8883"]
qos = 0
## Topics that will be subscribed to.
topics = [
"topic_name",
connection_timeout = "30s"
## If unset, a random client ID will be generated.
client_id = "telegraf"
## Username and password to connect MQTT server.
username = "admin"
password = "admin@123"
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
[[inputs.activemq]]
## ActiveMQ WebConsole URL
url = "https://b-1-1.mq.ap-south-1.amazonaws.com:8162"
## Required ActiveMQ Endpoint
## deprecated in 1.11; use the url option
# server = "192.168.50.10"
# port = 8161
## Credentials for basic HTTP authentication
username = "admin"
[[outputs.file]]
## ## Files to write to, "stdout" is a specially handled file.
files = ["stdout","/etc/telegraf/metrics.out"]
The data coming from devices is going to the queue, not the topic
As you can see the data is present inside the queue.
so now coming to my main question how I can read the data from the queue not from the topic using telegraf?
