How to query for special characters with CURL
In influxdb I can query for special characters with:
select * from "%" WHERE entity_id = 'air_quality_balcony' ORDER BY time DESC LIMIT 1;
But for curl this seems not working:
curl -k -G -u 'user:pwd 'https://url/query?pretty=true' --data-urlencode "db=home_assistant" --data-urlencode "q=select * from "%" WHERE entity_id = 'air_quality_balcony' ORDER BY time DESC LIMIT 1"
    "error": "error parsing query: found %, expected identifier at line 1, char 15"
How can this be achieved?
Thanks for your help!
Do you need to escape the special character?
I think the escape key is \ so possibly something like
curl -k -G -u 'user:pwd ‘https://url/query?pretty=true’ --data-urlencode “db=home_assistant” --data-urlencode “q=select * from “\%\” WHERE entity_id = ‘air_quality_balcony’ ORDER BY time DESC LIMIT 1”
Why do you have a measurement called “%”?
You’re an ace, @philb :wink:
Unfortunately this seems also not working.
Does it have something to do with using two sets of double quotes in the curl statement?
Damn, i thought that might fix it :frowning:
@mschae16 would it be a case of escape the inner double quotes as well or just remove the double quotes?
curl -k -G -u 'http://localhost:8086/query?pretty=true' --data-urlencode "db=home_assistant" --data-urlencode "q=select * from \"%\" WHERE \"entity_id\" = 'air_quality_balcony' ORDER BY time DESC LIMIT 1"
Does that work?
That’s the solution. Many thanks!
